How tight? Oil pressure sensor
Old May 7, 2009 | 05:39 PM
SunsetStroker's Avatar
SunsetStroker
Default How tight? Oil pressure sensor
I removed my intake manifold to be ported and found the oil pressure sensor that screws in behind the intake to be loose. How tight should I tighten it up?
Old May 7, 2009 | 06:40 PM
nwc6's Avatar
nwc6
Oil pres Sensor 35 N·m or 26 lb ft
Old May 7, 2009 | 07:17 PM
SunsetStroker
Like hand no no wait pinky tight!
Should I put some teflon tape around it?
Old May 8, 2009 | 07:49 PM
TEXHAWK0's Avatar
TEXHAWK0
That sounds too high... better double check the torque.
I was thinking it was more like 15 ft-lbs since everyone is always talking about being careful not to over tighten it.
Be back if I can find it.
Old May 9, 2009 | 09:50 AM
glass slipper's Avatar
glass slipper
The torque spec for the LS1 oil pressure sensor is 15 lb-ft according to the FSM. I don't have any C6 FSMs so I couldn't look it up. The LS2/3 sensor mounts in the same location, I would think the threads are the same so the torque spec should be the same. I wish I could tell you for sure before you strip some threads, maybe the guy that said 26 lb-ft will come back in and tell where he got that spec from.
Old May 9, 2009 | 02:50 PM
SunsetStroker
Thanks for the help guys.
Old May 9, 2009 | 03:43 PM
nwc6's Avatar
nwc6
Here is the C6 torque specs PDF from the David Farmer website:
http://www.davidfarmerstuff.com/C6-Torque-Manual.PDF
Old May 9, 2009 | 07:00 PM
glass slipper
David is most likely correct, but I'd still confirm it with the FSM...I'd hate to strip that hole in the block and have to heli-coil it. It'll be nothing but trouble from then on.
Old May 10, 2009 | 07:57 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
The Service Manual for my '07 says 26 ft-lbs.
Old May 10, 2009 | 11:28 AM
nwc6's Avatar
nwc6
As a side note about the torque specs. Cory Harris (ls2 portworks) and my tuner guy both told me not to torque the intake manifold bolts to 89 lb/in as specified in the torque spec from GM. I believe Cory made a post about the brass insert belling at the top and possible cracking the polymer manifold if tightened to spec.
To How tight? Oil pressure sensor
