Stupid Vararam tuning Question.
Old May 10, 2009 | 10:48 AM
trapp's Avatar
trapp
Default Stupid Vararam tuning Question.
Please excuse my lack of knowledge..but..When you install a Vararam intake that will force more air into engine as your speeds increase how can you tune for it on a dyno that doesn't account for the increase air flow.... as per maybe 100mph as compared to a fan on a dyno? Or are those changes not really that big.
Trapp
And no I'm not buying a fan from NASA for tuning.
Old May 10, 2009 | 11:23 AM
Danny318's Avatar
Danny318
The car has a MAF sensor which tell the engine exactly how much air it is getting, at whatever speed. It should be fine.
Old May 10, 2009 | 04:03 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Originally Posted by smoothbore
True story. The E C M will retune itself after about 30-50 mi,s Just drive the car and don't worry about it.
It's not a total picture - the ecm will make changes to the closed loop operation but only within its confines and sometimes, the LTFT's after a VR will fall outside the envelope and you need to recal.
At WOT the ecm is commanding a programmed set of instructions and it is in open loop - no learning here. If the MAF is still in range it will fuel accordingly, though. Run a wideband and change if you aren't optimized.
Old May 11, 2009 | 12:22 PM
CMY SIX's Avatar
CMY SIX
more air in, more air out=tune
Old May 12, 2009 | 11:40 AM
c6 batmobile's Avatar
c6 batmobile
on almost all setups you should be fine without a tune for just an intake. I ran my vararam for months without a tune and I had no issues. Not saying you wont but if you notice decreased performance tune it. If you plan on doing more mods wait till you get em and tune it then.
Old May 12, 2009 | 12:51 PM
trapp's Avatar
trapp
Any noticable difference on performance or sound?
Old May 12, 2009 | 06:19 PM
FLC6's Avatar
FLC6
Did you guys also get a Silicone Transition Hose that was too big for the MAF on one end with the Vararam?
To Stupid Vararam tuning Question.
