confused, rotation
Old May 12, 2009 | 11:59 AM
CMY SIX's Avatar
CMY SIX
Default confused, rotation
OK, I get confused easily, standing in front of the car, which way does the crank pulley go, clock wise? right? I'm going to adjust the RR' been awhile since install, THANK YOU!!!!!
Old May 12, 2009 | 12:12 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Clockwise.
Old May 12, 2009 | 03:02 PM
CMY SIX's Avatar
CMY SIX
Originally Posted by Tom400CFI
Clockwise.
thank you!
Old May 12, 2009 | 03:44 PM
Les-10's Avatar
Les-10
Bow-Tie Guy
Clockwise.
Get me straight please. Is that clockwise as you look at the balancer from the front of the car or does the crank rotate clockwise (toward the passenger side) within the block?
Old May 12, 2009 | 05:14 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The part in bold.
Old May 12, 2009 | 07:21 PM
vettl83's Avatar
vettl83
All shaft rotations CW or CC are determind by looking at the end of the shaft or "balancer," in this case CW will turn right and CC will turn left. To sumise anything turning off the rib surface of the belt is turning CW and anything turning off the smooth surface of the belt is turning CC.
To confused, rotation
