Anyone have any pointers on steam cleaning or power washing the engine bay? I want to make sure I don't get something wet than can be damaged or use any chemicals that may harm my plastics or such.
From: Greater Detroit Metro MI, when I'm not travelling.
I've power washed every single engine in every car I've owned, and also a few friend's cars... Never an issue. Just make sure the engine is not too hot when you begin.
Do I have to cover any electrical components on the C6 and any cleaners or degreasers to use ( SIMPLE GREEN ETC).
I never have. Just don't get the spray nozzle real close to any electrical connectors. I use Engine Degreaser on older cars but the C6 has never needed it...
For the most part the bay is clean but could use a good pressure wash to further clean it up...........Thanks for the tip Powerlab.
I have detailed thousands of cars during my lifetime (I used to own and operate a detail shop before becoming an attorney). This is what I have found to work for me:
NO HOT MOTORS - warm ok, but not hot.
Use a good degreaser - I use a citrus based degreaser made by Automagic (I think it is approximately $30 a gallon) that I cut 5 parts water to 1 part degreaser. I put it in a 2 gallon pump sprayer (less than $20 at Home Depot or Lowes). Spray it on and don't be cheap about it. Let it sit for 5 minutes.
I use a power washer with hot water (not quite steam but close enough for me). BLAST AWAY. It should melt off any crap on the engine and/or fender wells/firewall. Be smart about where and how you spray the water. While I have never experienced any problems with a modern motor, it is possible that you get something wet that could cause a problem. Of course, if you had an older car (cap and points), cover the distributor with a bag and be really careful about where the water goes. I did make my old school VW Beetle run like $hit for an hour back in 1986 but that is a different story.
Use shop vac on blower mode (or compressor) to blow off lots of water. Towel dry or run motor to dry out the balance.
FYI - same degreaser cut 15:1 cleans vinyl, leather. 10:1 to clean the tires. 1:1 - cleans anything greasy and oily. Straight will get oil stains out of concrete.
I use simple green in mine and its awesome. I dont even need a pressure washer just a hose with a spary nozzle. I DO cover my alternator, air filter, and coil packs just for safety.
We power wash the engines on our trucks at work (Chevy Silverado's) everyday. 40+ trucks. Never had a problem other than the power washer breaks down once in a while!
