axle/ nut issue
Old May 12, 2009 | 11:16 PM
jwillia2's Avatar
jwillia2
Default axle/ nut issue
Recently I have noticed a slapping or popping noise between shifts... I pulled my center caps off tonight, and while rocking the wheel back and forth (transmission slack) and holding the end of the axle in one hand, I noticed on the pass side I could move the axle up and down a little. This shouldn't have any slack at all correct??? I think the nut needs torq'd to spec, but can I just tighting it down till its snug for now, until I can get my hands on a wrench that goes to 160pounds?? Also the axle is rusted pretty bad... has anyone stripped one of these???
thanks
Old May 12, 2009 | 11:26 PM
calemasters's Avatar
calemasters
If the axle nuts are loose, the nuts should be replaced.
Use loc-tite
Torque to:
Rear Drive Shaft Spindle Nut
160 N·m
118 lb ft
Do not use impact.
Allow the loc-tite to cure for 24 hours before driving.
Old May 12, 2009 | 11:41 PM
jwillia2's Avatar
jwillia2
i cant turn the nuts (due to the rust) but they shouldnt be backed off enought to allow the axle to move around in the spindle right???
Old May 12, 2009 | 11:48 PM
calemasters
The axle shaft splines should fit tight in to the hub. There should be no transverse movement of the shaft relative to the hub.
Old May 13, 2009 | 12:35 AM
c6 batmobile's Avatar
c6 batmobile
yeah they shouldnt move. Like stated above red locktite and between 100 to 118 ft lbs. Any higher than that and they will break with hard driving. Many have experienced this problem.
Old May 13, 2009 | 11:35 AM
TEXHAWK0's Avatar
TEXHAWK0
Just retightening the axle nut may not stop the popping sound.
The sound is normally caused by a stick/release action of the inner bearing surface and the CV hub. You need to back the axle nut off, push the axle in a bit, and lube the "inside" portion of the axle spline and the bearing face. Then retorque the nut to 118 ft-lbs.
GM recommends that you replace the nut since they are interference fit, but you can also use loctite.
I retorqued the nut on my C5 without loctite, and have not had a problem with the nut backing off.
Old May 13, 2009 | 11:38 AM
Marina Blue's Avatar
Marina Blue
Axle nut torque was originally listed at 118 ft.-lbs., but revised in a TSB to 160 ft.-lbs. Assembly procedure at the plant was changed after many reports of loose axle nuts. As previously stated, a loose axle nut must be replaced with a new nut and then torqued to 160 ft.-lbs. with red loctite. I relied on memory for the new torque specification, so check with your dealer first.
Old May 13, 2009 | 01:08 PM
TEXHAWK0's Avatar
TEXHAWK0
As pointed out, retorquing at the higher 160 ft-lbs may actually stretch the axle and result in failure if you are pushing the axle to the limit.
Old May 14, 2009 | 09:46 PM
jwillia2's Avatar
jwillia2
tight now and no more noise..... thanks again!!! turned 3/4 turn on the pass side...
To axle/ nut issue
