Tune
Old May 13, 2009 | 07:04 PM
Revolver-time's Avatar
Revolver-time
8th Gear
Default Tune
I am new to the computer controlled engines. In my time, performance was 10 to 1 pistons, a dual-plane intake, 3/4 cam, headers, and a duel point distributor. Yeah I have been out of it for awhile. But now I am back with a C6, LS2, 6 speed manual. I read here that a cold air intake, 160F thermostat and a tune would give me a little more motivation. What is a "tune" ?
Old May 13, 2009 | 07:34 PM
RAT_FINK's Avatar
RAT_FINK
optimized engine management....Pcm tuning in your case will dial in timing, fueling, fan speed and almost all other Engine function.. Cars in stock trim are targeting economy and federal emissions guidelines, not HP. Tuning in most instances targets HP and optimizes all around performance. Find a reputable local tuner or there are tons of awesome vendors who tune on this site
Old May 13, 2009 | 08:10 PM
c6 batmobile's Avatar
c6 batmobile
A good tuner can unlock almost 30 hidden hp on your stock motor. Almost everything can be controlled from you pcm/ecm from timing to idle right down to when the fan turns on and off. I had mind tuned when bone stock and picked up 26rwhp. Get it tuned and see what youve been missing.
Old May 13, 2009 | 08:22 PM
Revolver-time
8th Gear
Wonderful,
Does anyone have a trusted "Tuner" in the Savannah, Ga. area to recommend?
Old May 13, 2009 | 09:17 PM
nwc6's Avatar
nwc6
So now you have 10.9:1 compression ratio, a coil per spark plug, and fully electronic engine controls. You've come a long way...If you are going to get a tune, and possibly void your warranty, (if any), I would wait and get a set of headers to go with the tune. That will really wake up the beast in the LS2...Congratulations on the vette and welcome to the perma-grin society..
Old May 14, 2009 | 09:25 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
This Guy is good. He might do a trip to Savannah if there is enough interest
http://forums.corvetteforum.com/sout...une-trips.html
Old May 14, 2009 | 09:36 PM
teuhl's Avatar
teuhl
Wonderful,
Bring to Atlanta and have tuned by MTI Racing
Old May 14, 2009 | 10:35 PM
Mrs. CoW's Avatar
Mrs. CoW
Give Chuck CoW a call, he will answer any questions you have about tuning, and probably tell you more than you ever wanted to know about it
You won't be disappointed and you have nothing to lose, it's just a phone call
His number is 914-332-0049
FireEyes
To Tune
