Trouble Code P0341 Help!!!
Old May 16, 2009 | 11:35 PM
mhoglund's Avatar
mhoglund
Default Trouble Code P0341 Help!!!
HP Tuners is the software being used. The cam was installed with 2 degrees of advance, per the verbal instruction I was given be EPP. Now the car is being tuned and were getteing a P0341 code. The car was diffacult to start, the tuner says he adjusted that but the code remains.
Mods:
Bassani Headers with high flow cats, Bassani aft cat system with built in X pipe, Magnacharger MP112, EPP Blower cam,Crane extreme duty duel springs, AFR 205's, Comp cams heavy duty timinig chain, Comp pushrods, Yank 3000 stall.
Old May 17, 2009 | 04:26 PM
valsperformance's Avatar
valsperformance
1st Gear
Default P0341
Matt, I was discussing this with the guy who helps with some of our builds and we are thinking that you might have the wrong cam gear installed. I guess there is a changeover from 3 bolt to 1 bolt in 06 and you have to have the correct one not to trip the code. If you can remember which one you have call Joey Monday and I will figure out if it is the correct one. Todd might remember if he installed a different style gear also. Give that a try. I'm surprised it starts as well as it does but it does long crank quite often.
Old May 17, 2009 | 06:26 PM
mhoglund's Avatar
mhoglund
I did use a Comp Cams timing chain, I hope it was the correct one
Old May 22, 2009 | 09:25 PM
mhoglund's Avatar
mhoglund
All fixed now, just a couple of connections were reversed. Thanks for everyones help.
Old May 22, 2009 | 09:35 PM
VET4LES's Avatar
VET4LES
Good news.
Old Dec 6, 2020 | 11:20 AM
curtisb23's Avatar
curtisb23
old bump. What connections? My car is doing this after a motor swap.. never had problem before.
To Trouble Code P0341 Help!!!
