Service active handling woes
When I purchased our 06 Z51 six speed Coupe, I thought that I would not have to ever worry about EBTCM issues. GM surely would have learned a lesson and made the module better than the C5 EBTCM module.
During the warranty period, I had the dreaded SERVICE ACTIVE HANDLING message on the DIC.
I had the dealer fix it and they fixed some wire on the steering column. Good up until last week.
The wheels and tires are stock and its happing when driving straight, level, smooth road.
Im going to call the Customor Assistance Center and see what they say about service after the warranty on something that was serviced during the warranty period.
So,,,now its out of warranty and the messages are happening daily. I checked for DTCs with an actron scanner that checks for all DTCs and NONE are being displayed. They will clear upon cycling the ignition as expected but come back after driving for a while.
Whats the latest C6 Forum word on this type of failure of this module??
Any body else seeing this failure or had to deal with fixing what is causing these messages??
Bill
Bill
I also have the "Service Active Handling" DIC and my scanner produce no codes. It is an AutoRay Code Scout which has served me well.
What have you tried? Any success?
TEd
Do you have a copy of the TSB?
with Steering Wheel - Tilt, Telescoping (RPO N37 or N38)
This bulletin is being revised to update the models and provide new correction information. Please discard Corporate Bulletin Number 06-02-35-002A (Section 02 -- Steering).
Condition
Some customers may comment on a Stabilitrak® or Active Handling System light being illuminated. Also, this warning light will be accompanied by a SERVICE STABILITRAK or SERVICE ACTIVE HNDLG message on the DIC.
Diagnosis with a scan tool may reveal a DTC C0710.
Cause
The most likely cause of a DTC C0710 on a vehicle equipped with telescoping/tilt steering wheel is high resistance in SWPS connector C202. Fretting terminal corrosion may be present in the SWPS connector due to the telescoping motion of the steering column. When the steering column is telescoped in and out, the female terminals within the SWPS connector may move on the male terminals of the SWPS. This movement between the terminals may cause a high resistance condition in the SWPS connector.
Correction
Remove the driver's side closeout (insulator) panel.
Locate the SWPS connector that connects to the steering angle sensor, located on the lower center of the steering column.
Install the clip (1), P/N 19179794, into the connector. This clip will act as a terminal positive assurance (TPA) and prevent any movement of the terminals.
Reinstall the closeout panel.
Clear the DTC with a scan tool and road test the vehicle.
If DTC C0710 resets during the road test, refer to DTC C0710 in SI.
Parts Information
Part Number
Description
Qty
19179794
Clip, Steering Angle
1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E9464*
Install Clip into Steering Wheel Position Sensor (SWPS) Connector
0.3 hr
BC
Rob
