Where is your Trans Cooler..
Old May 19, 2009 | 08:23 PM
jpee's Avatar
jpee
Default Where is your Trans Cooler..
I'm putting in a Hi Stall converter, & want to also install a Trans cooler.. where are you guys putting the cooler..
On my 96 it was a no brainer.. right on the front of the condenser... but with my Trans (A4) in the rear, I don't know where to put the cooler..
Tkxx
Old May 19, 2009 | 09:28 PM
c6 batmobile's Avatar
c6 batmobile
I posted some pics on here a while ago. Try the search function and see what it yeilds. If nothing Pm me and Ill get you some pics.
Old May 19, 2009 | 09:35 PM
jpee's Avatar
jpee
Thanks.. I did do a Trans cooler search.. I'll try it again.. how high is your converter? I'm looking at a 3200
Old May 19, 2009 | 09:37 PM
c6 batmobile
I have the yank 3200. I have to cooler mounted up front at an angle on the little piece of plastic inside the front bumper. Like I said if you cant find it just let me know and Ill will get some pics posted by tomorrow morning.
Old May 19, 2009 | 10:37 PM
Pro Stock John's Avatar
Pro Stock John
I'd like to see pics.
Old May 19, 2009 | 10:42 PM
jpee's Avatar
jpee
I'd appreciate it if you could post them as I cant find the photos.. if you mount it in the FRONT I imagine you have to run lines from the rear (trans) to the front (where the cooler is)
thanks....
Old May 19, 2009 | 11:15 PM
danl72's Avatar
danl72
Old May 20, 2009 | 12:08 AM
c6 batmobile
http://forums.corvetteforum.com/c6-t...on-cooler.html
This is the thread that I posted a few pics in. If you need a few more I have them. I also have a few pics of a friends mounted in the same spot that are a little clearer than mine.
Old May 20, 2009 | 12:10 AM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
John
Disconnect the lines from the trans to the cooler in the radiator (pass side of car) install barbed hose connector in existing cooler line to new cooler lines, tighten with clamps. You can now install the cooler in front of the condenser like your C4.
Old May 20, 2009 | 12:25 AM
jpee's Avatar
jpee
Originally Posted by Tommy D
John
Thank you... I didn't know I had a cooler in the radiator.. that will make it a much easier job !! Thank you...
In my 96 I had a "Stacked Plate" NOT the finned aluminium.. and it worked like a charm
To Where is your Trans Cooler..
