Changing coolant in a C6
Old May 20, 2009 | 12:11 AM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
Default Changing coolant in a C6
I'm getting ready to drain and refill the coolant in my 05; are there any suggestions or "tricks" I need to be aware of? What about draining the block? Thanks in advance for any help.
Old May 20, 2009 | 12:14 AM
c6 batmobile's Avatar
c6 batmobile
Do you know where the coolant drain is? If so you are way ahead of many others that have done this before you. Its in the lower side of the radiator passenger side of the vehicle. As for draining the block I hooked up a shop vac to the radiator hose and sucked it out. But there aint much in there that would affect your new fluid unless you are going from orange to green.
