vortex pre cut shroud
Old May 20, 2009 | 01:18 AM
White_Lightning's Avatar
White_Lightning
Default vortex pre cut shroud
anyone know where you can buy a pre cut shroud for a vortex ?
thanks in advance.
Old May 20, 2009 | 01:27 AM
siffert's Avatar
siffert
thanks in advance.
I think the same place you can buy a pre-cut shroud for the Callaway...nowhere!
Old May 20, 2009 | 08:40 AM
White_Lightning
hmm.. my bad.. i was sure one of the site vendors had precut shrouds.. thanks anyway.
Old May 20, 2009 | 12:36 PM
siffert's Avatar
siffert
No problem. I think its sad when vendors selling CAI's that require cutting the shroud, do not make available pre-cut optional one. My Xcelerator had one precut and pre-riveted available. To their credit, I believe Vararam does.
Old May 20, 2009 | 03:12 PM
John Mclain's Avatar
John Mclain
thanks in advance.
You are correct the PC was once offered. I purchased the Pre-Cut shroud from Ecklers along with my Rammer intake back in 02.
Ecklers no longer offers the pre-cut shroud because it isn't offered to them anymore from Breathless Performance.
You could pick up the OEM GM Shroud from your dealer, cut it out on the bench with no worries and then swap it out with your in car original.
Beats hacking away bent over with low visibility in the compartment and you can tuck the original away.
Old May 22, 2009 | 05:03 PM
dkrhardy's Avatar
dkrhardy
If you can swap out for the extra one, why can't you remove the one on the car, cut IT on the bench and re-install it? From all that I've read here, you do NOT want to try to cut it while it is on the car!
Old May 23, 2009 | 09:56 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
I did mine on the car, it was APITA, but it turned out great.
I did hear of someone that puntured their A/C condenser, take your time.
To vortex pre cut shroud
