Need Help with wire for fan
Old May 21, 2009 | 12:05 AM
jpee's Avatar
jpee
Default Need Help with wire for fan
I just got a switch to run the fan .. I have to run a wire from the engine compartment to the interior... where is the easiest way to get a wire into the cockpit from the engine..I cant find any holes in the firewall ?
Old May 21, 2009 | 12:44 AM
HOXXOH's Avatar
HOXXOH
Near and behind the battery is where multiple wiring harnesses go through the firewall. There is usually enough space to shove one more small wire through the grommet.
Rather than a light to remind you to turn the fan off, you might think about getting a timer to break the circuit. Just set the time and forget it. No memory required.
Old May 21, 2009 | 02:35 AM
jpee's Avatar
jpee
excellent idea... I'm going to Radio Shack tomorrow to see what is available..
To Need Help with wire for fan
