Fuel Starvation
Old May 23, 2009 | 02:43 PM
sacegielski's Avatar
sacegielski
Default Fuel Starvation
I think my engine is starving for fuel when hammering down on the gas pedal. I'm still using stock injectors, but have a LSX455 (535rwhp/567rwtq) under the hood. What size are the 07' C6 stock injectors? What size should I be using? My understanding is the fuel pump produces roughly 58lbs of pressure so going with 42lb injectors would make them equal to 51lb injectors. I'm confused and I haven't found the answers via search feature included on the forum.
Old May 23, 2009 | 04:15 PM
oneblackvette's Avatar
oneblackvette
Here is what you need. Direct plug and play.
http://www.racetronix.com/M145FM2.html
Old May 23, 2009 | 04:18 PM
sacegielski
How were you able to come up with that specific size?
Old May 23, 2009 | 04:39 PM
NYC6's Avatar
NYC6
I have 60 lb ones in my Vortech car, that seems to be the popular size with 500 plus HP cars.
Old May 23, 2009 | 05:10 PM
sacegielski
While it might be popular, I truely want to understand how to come up with the correct size injectors.
I'm not looking for someone to post up links of those sites where you put in approx hp and it shoots out a basic fuel injector size. From my understanding, our fuel pumps have x amount of constant pressure, so we have to compensate for that in order to get the correct injector. With that in mind, it seems like we might be able to get away with smaller injectors based on the constant fuel pressure from the pump.
I hope I'm making sense (lol) because I'm on the brink of confusing the hell out of my own self - ssshhhhh.
Old May 23, 2009 | 05:33 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
First, I believe that 58PSI for the fuel pressure is the stock amount.
I don't think we have rising rate fuel regulators in the cars so the fuel pressure will fall as you go higher in RPMs while at WOT.
Putting higher fuel injectors would be helpful if you had more pressure to sustain them. That would mean that you would need a higher volume pump. Something like a Walbro 255 or the like.
Even with higher FIs, you need to keep the pressure level and that would take a different fuel pressure regulator or a boosta pump to run the pump at a higher volume.
What I'm trying to say is with your HP, you need a fuel system not just larger fuel injectors.
My $.02
Elmer
Old May 23, 2009 | 05:37 PM
eboggs_jkvl
Moderator emeritus
Scroll down on this and plug in your numbers to determine Injector size:
http://www.rceng.com/technical.aspx#...Injector_Size_
Remember it asking for BHP, not RWHP. I believe that BHP would be higher than your 535 RWHP. I used 600 as the number and 42 Pounds would work. I'd personally just get the 60s and allow for growth in the future.
Elmer
Old May 23, 2009 | 05:56 PM
CPG1962's Avatar
CPG1962
St. Jude Donor '09-'10
My $.02
Elmer
I agree as most would with FI. I run 700hp and look for 60-65 psi at ALL times. Be Careful! You may want to consult with a reputable shop on this one - you will need a boostapump.
Old May 23, 2009 | 06:25 PM
sacegielski
Elmer
So I plugged in my numbers (using 660 as BHP) and I'm getting 51lb injectors as the needed size. However, when I put in the number you used, 600, I'm gettin 40lb injectors. Not trying to dispute the info you provided, but wondering if you used a different number for the "system fuel pressure @ the fuel rail" than what the default setting was on the website. The website default number for system fuel pressure is 43.5. At 43.5 fuel pressure I need 51lb injectors, but with 58 as the fuel pressure, I need 44lb injectors.
Am I getting close or on the right track? System fuel pressure seems to be a key factor to ensure correct injector size. Any thoughts?
Old May 23, 2009 | 06:41 PM
eboggs_jkvl
Moderator emeritus
I used 58 PSI at the fuel rail, 600 BHP, .50 for NA, not .65 Forced Induction, 8 injectors, and 80% injector limit. The OP doesn't mention SC or turbo. Nothing but a big cam.
Those numbers give 40.59 for injector size.
I show 52.77 injectors when I go to turbo "needs" and .65 in the brake specific fuel consumption box.
You should enter your fuel rail pressure. You surely don't run 43.5 do you?
My old Camaro had 550 to the wheels. I ran an Aeromotive 1000 pump, a rising rate fuel pressure regulator that raised the fuel pressure 1 PSI for each pound of boost. I started at 58 and topped out at 70 PSI fuel pressure at full boost of 12 on the car. My fuel injectors were 60 pounders and I had -10 AN fuel lines to the rail with -8 lines on the return. I had a jump switch on the fuel pump that raised the pump voltage under boost and gave the higher volume to the engine. If you're blown, do it right or pray often!
Elmer
Old May 23, 2009 | 07:21 PM
sacegielski
Elmer
At the moment, there is not FI of any sort on the car - all motor. However, future plans do include some sort of FI, but for the moment I want to address the fuel issues at hand while not over planning for the future. If this is even possible.
At any rate, I entered my fuel pressure as both 43.5 and 58. While I'm still green with the idea of how system pressures work, 58 seems to be the comfortable variable for me. 58 is only based on what I've been told. BTW, is 58 what you typically would use for your vehicle prior to FI? Honestly, I'm not even sure 58 is my system fuel pressure. I'm only taking it for granted because I know no different, nor found anything which says otherwise. Presently, I'm under the assumption all stock C6 LS2 fuel systems should have the same pressure. Since mine hasn't been altered, I can only assume I'm still under stock pressure.
Old May 23, 2009 | 07:49 PM
eboggs_jkvl
Moderator emeritus
Yes 58 is what you get out of the box. The only reason my rig was complicated was the Forced Induction. You're cam is giving you a lot of HP and you need more gas. Do you have the ability to get the car hooked up to a wide band O2 sensor and some tuning software? Do you know how bad your fuel starvation is? I'd guess that you are having issues with fuel injector size and fuel pressure both. You can't work on this by just getting bigger injectors. The bigger injectors will require you to have a tuner reset your injector flow rate in the ECM to reflect the bigger injectors. This is not as easy as adding big injectors and saying, fixed.
Old May 23, 2009 | 07:52 PM
eboggs_jkvl
Moderator emeritus
Here is a film of the fuel system on the Camaro.
http://www.ls2.com/boggs/98tank/ETANK.wmv
It is a large file so be patient. Windows Media Player will play it.
Old May 23, 2009 | 10:39 PM
sacegielski
I do have the "bung" which allows for a wide band O2 sensor and tuning shouldn't be a problem. Granted, I won't be the individual to retune the vehicle, but nonetheless it's something I've already taken into consideration.
At the moment, I'm not certain as to how bad the starvation is. Right now, I'm assuming max duty cycle on the injectors has been reached based on the power output from the motor. The only symptoms I've seen have been a lag in response from when I mash the petal to when the car actually catches up with whats happening. Once it does catch up, then I can feel the loss of traction - two very distinct feelings. So in essence, I have two issues I'm working to resolve. Fuel & traction.
After running the numbers through the formula you had given, what I noticed was with a bigger fuel pump (assuming system pressure goes up with the bigger pump), you can get a way with smaller injectors. Just as bigger injectors can compensate for a smaller pump - up to a certain point of course. This is only based on raising and lowering the fuel pressure within the forumla.
It doesn't seem like the whole fuel system needs a revamp. I'm wondering if slightly bigger injectors (44lbs) and a fresh retune will solve the problem. What do you think?
Old May 23, 2009 | 10:43 PM
sacegielski
Very nice install and extremely clean engine bay.
I like the setup on your Camaro. If only the fuel pump was as accessible on the C6 as you have there. From the looks of it, you had a custom made tank, no?
Old May 24, 2009 | 10:33 AM
eboggs_jkvl
Moderator emeritus
Yes, the tank is a "Rick's" custom stainless tank. It has the Aeromotive 1000 pump submerged in it. The C6 pump in the tank tank is seriously nasty to get at. Usually the Forced Induction forum has more "fuel" related information. They will explode if they lose fuel so they take extra precautions to "hold" pressure in the fuel and often, as in the Camaro, actually raise fuel pressure. I'd fumble around in that forum and talk fuel stuff with them.
Elmer
Old May 24, 2009 | 11:20 AM
Torlow's Avatar
Torlow
dont confuse fuel system pressure (psi) with injector flow rate (lb/hour).
The two work together but are not the same thing and cannot be "balanced" based on their values.
To Fuel Starvation
