Service active handling
Old May 25, 2009 | 11:35 AM
btstone84's Avatar
btstone84
Default Service active handling
Sorry bout all the questions guys. Thanks in advance for the help
I just got my car back from dealer for having the sensor in the steering wheel replaced cuz it kept locking down the car while I was driving. It's an 05 a4
This morning I get in the car and the "service active handling" is flashing all over the dash. Am I having more issues with the active handling? Once I cut the car off and turned it back ok it went away..... Is it gonna come back?
Old May 25, 2009 | 01:08 PM
Wass's Avatar
Wass
St. Jude Donor '09-'11
Ask your dealer to check the GM technical bulletin on this issue. There is a small plastic clip they can install inside the steering column to eliminate the problem. Takes about 20 minutes to perform.
Old May 25, 2009 | 03:23 PM
als2052's Avatar
als2052
Being that the 05's are out of warranty, how much $$ is this going to cost? I had the wire tie bit done 2 years ago but now I am getting the message again intermittently...
Old May 25, 2009 | 09:06 PM
Wass's Avatar
Wass
I had the same thing happen. The second fix seems to be working. The part cost is about $10-$15 and whatever labor is for a 15-20 minute job. Not too expensive. However, I told the service manager I didn't want them to do a computer analysis to determine the problem...Just do the tech. bulletin fix. That probably saved me $60.
Old May 25, 2009 | 09:25 PM
btstone84's Avatar
btstone84
but will this keep happening..and is something actually wrong with my active handling or is it just computer going nuts?
Old May 25, 2009 | 09:36 PM
danl72's Avatar
danl72
Old May 26, 2009 | 02:50 PM
Wass's Avatar
Wass
This link will provide more information on the subject. http://forums.corvetteforum.com/c6-c...post1565795941
Best to get it fixed, and if it just needs the clip it won't take long to do or cost much, and then it should be fixed for good. I guess it's your choice whether you want the mechanic to check for codes or merely perform the TSB. In my case, I was fairly certain the TSB fix would work, so I just told them to do it. It worked!
The TSB is (or was, may have been updated) bulletin 06-02-35-002.
Old May 26, 2009 | 07:58 PM
tmak26b's Avatar
tmak26b
I had an intermittent problems that turned out to be the pulley eating the wiring harness. I dont think that is the problem with your car as my light would just go on and off after i restart
To Service active handling
