Re-Sleeving an LS7
Old May 26, 2009 | 02:06 AM
dfinke23's Avatar
dfinke23
Default Re-Sleeving an LS7
Anybody had experience resleeving an ls7? If so, please elaborate.
Old May 26, 2009 | 01:03 PM
NIGHTSTALKER's Avatar
NIGHTSTALKER
Darton offers high performance sleeving options....To the tune of LSX Block-type strength..... Our buddy from Delaware his his block there as we speak....He's got big plans for that car!!!!
What happened to yours?
Old May 26, 2009 | 06:35 PM
aTX427
Guest
Posts: n/a
Had mine done by Race Engine Development in Carlsbad, CA.
Old May 26, 2009 | 08:06 PM
under pressure's Avatar
under pressure
had mine done at erl they call it a superdeck 1 ...correct and only way to do it is do all 8 holes!! mine was superdecked with daton sleeves and studed ...in the end its 10x stronger then what gm gives you!
Old May 27, 2009 | 06:09 AM
glass slipper's Avatar
glass slipper
The Darton sleeves referred to above are ductile cast iron vs stock factory sleeves made from gray cast iron. The ductile cast iron has superior strength and ductility and is the only way to go for high HP applications.
http://www.flowserve.com/vgnfiles/Fi...ulletin_a6.pdf
You'll note gray cast iron does not have a yield strength or elongation because of its' lack of ductility...it simply cracks in the presence of impact loads exceeding its' relatively low tensile strength like detonation or high boost in cylinder sleeve applications.
Old May 27, 2009 | 12:54 PM
CMY SIX's Avatar
CMY SIX
if GM gave it to you this way, you'd still be bi@#$then about the price!
Old May 27, 2009 | 07:59 PM
under pressure
You get what you pay for...now its bullet proof...
Old May 27, 2009 | 10:59 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
What does it cost for a full re-sleeve?
Old May 28, 2009 | 02:37 AM
dfinke23's Avatar
dfinke23
$1500, alot less than a new grey-sleeved LS7 block.
Old May 28, 2009 | 02:38 AM
dfinke23's Avatar
dfinke23
I broke the #5 piston and cracked the sleeve at Katech's Track Attack. Is your turbo car broken in yet?
Old May 28, 2009 | 09:25 AM
BAADC6's Avatar
BAADC6
The turbo car is broken in we had to swap the heads to LS7 heads. There were to many clearance issues with the warhawk heads and the turbo manifolds/plug wires..plug angle was a little different than GM with the warhawks and it caused the spark plugs to almost touch the turbo manifolds With about 5.5 lbs of boost we made 663rwhp/620rwt. we are now at about 8.5lbs of boost...it is scary fast The M&H 345/18drag radials can't hold the power at any speed. If it stops raining I'll get it to Ed for the final dyno this week or next. Good luck with the new sleeves
Old Jun 17, 2009 | 07:23 PM
drivinfast's Avatar
drivinfast
Great that was my next move
Old Jun 17, 2009 | 08:09 PM
Sparo2's Avatar
Sparo2
That doesn't include the sleeves does it?
Old Dec 12, 2009 | 10:04 PM
copo9560's Avatar
copo9560
I believe this includes the sleeves but this is for the dry application. Darton also makes a wet MID sleeve for LS7 block that costs more to install but looks far stronger.
Old Dec 13, 2009 | 05:19 AM
Sparo2's Avatar
Sparo2
What's the differences between the "dry" and "wet" sleeves?
Old Dec 13, 2009 | 09:47 AM
1.8t's Avatar
1.8t
I believe whether it touches the coolant or not.
Old Dec 11, 2025 | 03:52 AM
3R1$C's Avatar
3R1$C
I was told by Darton that the wet sleeve project is not somthing that works well. Dry sleeving is the best way to get it done.
Wet sleeves worked well on the LS1, which had longer head bolts, that would clamp the cylinder length to the bottom of the block. That was changed for cost reasons later. Wet sleeves leak water into the chamber easily as the clamping force does not properly compress it well.
To Re-Sleeving an LS7
