C5 rearend in a C6??
Old May 26, 2009 | 02:46 PM
SunsetStroker's Avatar
SunsetStroker
Default C5 rearend in a C6??
Took my car to get the new clutch put in today. Very excited to feel the Mosnter stage 3 and the chromoly flywheel. Anyhow the tech is cool as all get out and offers to put a hardened output shaft in at no charge for labor. I called around and researched and have come to find on the 05 its the housing not the shafts that are the problem. The shafts are the secondary problem.
Ive seen a few guys on here that have replaced with a c5 rearend but cant find any how to or good info on the subject. Can someone point me in the right direction?
Also I read something about replacing driveshaft bushings or something while doing the clutch? Anyone?
Thanks guys!
Old May 26, 2009 | 04:26 PM
dennis50nj's Avatar
dennis50nj
Thanks guys!
Cartek
Old May 26, 2009 | 04:53 PM
SunsetStroker
Originally Posted by dennis50nj
Cartek
Expensive!
Old May 26, 2009 | 06:46 PM
dennis50nj's Avatar
dennis50nj
Expensive!
not if you didnt blow yours yet and can sell it
Old May 26, 2009 | 09:43 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Cartek
Yep. My Cartek adaptor bracket is working great. C5 rears are about 50% cheaper than c6's.
Here's what happens to 05 rear ends....mine happened after 301 drag strip launches. I thought I was gonna beat the odds but fate caught up with me.
Oh and it took out the transmission mainshaft too...that was a pricey break.
Old May 26, 2009 | 09:51 PM
BAADC6's Avatar
BAADC6
I had the Cartek C5 rear upgrade. It held up well.....yes Dennis...I said something good about it
Old May 26, 2009 | 09:56 PM
BAADC6's Avatar
BAADC6
Thanks guys!
I would upgrade to ZO6 stuff. I don't know what is involved. I just swapped everything with my last build. I bet Ed at B&P has my old Cartek C5rear sitting on his floor. You could probably get a good deal? ? it has 4.10's
SunsetStroker
Whats it run??
Old May 27, 2009 | 01:19 AM
NIGHTSTALKER's Avatar
NIGHTSTALKER
Remember what was holding that rear to the subframe
Old May 27, 2009 | 01:29 AM
LS1LT1's Avatar
LS1LT1
Expensive!
So is every single other option available LOL.
The words inexpensive and rear replacement don't quite go in the same sentence when discussing late model Corvettes.
I too would probably go with the latest C6 Z06 rear (or better yet, C6 ZR1 rear) conversion if money was no object.
Old May 27, 2009 | 01:34 AM
LS1LT1's Avatar
LS1LT1
Dennis, you should make an offer on that, 4.10s in an A4 is a little bit much but then your car could maybe sixty foot in the 1.3s!
Old May 27, 2009 | 01:53 AM
blu00rdstr's Avatar
blu00rdstr
Now that's interesting, I'm moving parts from my A4/2000 C5 (LS3, etc) to my M6/2005 C6. So the C5 diff is a direct bolt-in?
Old May 27, 2009 | 02:02 AM
NIGHTSTALKER
It is NOT a direct bolt-In
Old May 27, 2009 | 02:03 AM
c6 batmobile's Avatar
c6 batmobile
Spinmonster has this done to his ride as well. Im not sure if he took it to someone or did it himself. Pm him and have him give you some info.
Old May 27, 2009 | 04:59 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
When mine grenades I've already decided to swap in a C5 diff using the Cartek kit.
Old May 27, 2009 | 05:44 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
a mounting bracket has to be welded in to use the C5 rear .........If you want to play you have to pay
Old May 27, 2009 | 06:15 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Do yourself a favor, sell the C6 rear before you turn it into to this.
Save yourself the $1k or so your rear is worth.
To C5 rearend in a C6??
Old May 28, 2009 | 01:27 AM
blu00rdstr's Avatar
blu00rdstr
I exchanged PMs with Spinmonster, the mount is the issue which requires welding a new lower tab to the crossmember and fabricating a new trans mount. Besides that looks like it'll bolt up to the trans. Cool, I can send my C5 diff out for beefing up while I drive around in the C6, looks like a $1,400 difference in price. Next I have to consider what the trans brace would look like with a C6 trans and C5 diff...
C6 Diff
C5 Diff
Old May 28, 2009 | 09:38 AM
BAADC6's Avatar
BAADC6
Whats it run??
I blew up the C6 rear...nothing left that was good. The new C5 with 4.10's and both hardened shafts was about 3K installed. Yes they have to weld a bracket and make a few mods...but it fits OK. the bracket is bolted to the car with two 10mm bolts....doesn't look very strong, but I run my car hard and it held up.
Old May 28, 2009 | 11:49 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
C6 Diff
C5 Diff
I had the c6 brace on my car when I blew the rear, and my trans mainshaft bent causing me to have to replace the trans. That is an expensive proposition.
The c6 brace has only 2 bars. The c5 brace has 4 bars, and several of my buddies have blown their c5 rears and have NOT had to replace their trans, so I think the c5 is a much better design.
I have not put on the c5 brace yet..I have stopped launching hard instead. I cannot afford another $6k aw $h!t...so those records in my sig will stay that way for a while.
