Lowering question
Old May 26, 2009 | 03:20 PM
2kvert's Avatar
2kvert
Default Lowering question
Will the shocks bottom out like my C5 did after lowering? 07 coupe Z51.
I'm not gonna slam it, just about an inch or so.
Old May 26, 2009 | 04:19 PM
adam205348's Avatar
adam205348
I have not seen anyone run into that problem with lowering all the way on the stock bolts, and I really havent heard anyone have that problem with the West Coast Corvettes lowering bolts.
Old May 26, 2009 | 08:34 PM
c6 batmobile's Avatar
c6 batmobile
The only problem I have heard and read about here on the forum is that if you do not grease the wcc bolts every couple of months the rubber/plastic comes off of them and they squeak like crazy.
Old May 26, 2009 | 08:38 PM
Jutskin's Avatar
Jutskin
No issues here, and I'm floored.
Old May 26, 2009 | 09:54 PM
BOB EAGAN's Avatar
BOB EAGAN
I thought my car looked good, yours looks great. Nice job.
Old May 26, 2009 | 11:47 PM
namor's Avatar
namor
No problems with lowering the car, just have a alignment done after you install the lowering bolts asap.
Old May 27, 2009 | 10:47 AM
KewlFunGuy's Avatar
KewlFunGuy
Default Lowered on Stock Bolt's
I have my 05 lowered on stock bolt's (rear bushing cut) w/o any issues. I did have to raise it a little when I added Koni FSD's.
Old May 27, 2009 | 11:55 AM
adam205348's Avatar
adam205348
That looks good. I have been hesitant to lower mine because I dont to grind the front airdam on every dam thing. But I think i have reconsidered.
Old May 27, 2009 | 10:51 PM
'VETTE PHASE's Avatar
'VETTE PHASE
Cruise-In VIII Veteran
Go ahead and do it. The airdam is designed to scrape, it is spring mounted so it just flips right back after you hit it.
Old May 28, 2009 | 04:29 PM
paleale's Avatar
paleale
ok i still have had many people answer this in both ways...do you NEED to get alignment after lowering on ONLY the stock bolts? I am sure if you used aftermarket as this would be even lower. But just turnign down the stock bolts does that require a trip in for alignment ...
Old Jun 4, 2009 | 01:59 AM
Ed 718's Avatar
Ed 718
Did you cut the bushings or are you on aftermarket bolts? Looks great by the way......
Old Jun 4, 2009 | 08:11 AM
Jutskin's Avatar
Jutskin
Bushings are cut .....plus no more turns on the bolts.
Bought the car already lowered....I did the flat black stuff.
chris
Old Jun 4, 2009 | 08:40 AM
Nightstalker Medic's Avatar
Nightstalker Medic
Lowered mine on stock bolts with no cutting. No issues
Right after took the car dealership and had then check the alignment. They put it on alignment machine and told me all is good. It's a very good idea to get it checked out.
To Lowering question
