Stock ls3 valvetrain question
Old May 28, 2009 | 01:47 AM
White_Lightning's Avatar
White_Lightning
Default Stock ls3 valvetrain question
What is the safe limit of the Valvetrain RPM wise? i want to bump up my limiter slightly so i can shift at 6600 instead of smacking into the limiter at 6600.. say move it to 6800ish... how does the stock valvetrain hold up to this?
Old May 28, 2009 | 11:24 AM
CMY SIX's Avatar
CMY SIX
why do you want to shift at 6600? I think GM put the limit there because they thought that was the safe limit. you think?
Old May 28, 2009 | 11:44 AM
White_Lightning
why not shift at 6600? if that is the rev limiter.. then that is a perfect place to shift i still plan to shift there.. just want to bump up the limiter a little so when i shift dead at 6600 with the laggy tach im not tagging the limiter.
To Stock ls3 valvetrain question
