Heating Up
Old May 29, 2009 | 12:22 PM
mariomark's Avatar
mariomark
Default Heating Up
How high of a temperature reading should I expect on an '06 auto trans?
Old May 29, 2009 | 01:08 PM
Lil' Red Corvette's Avatar
Lil' Red Corvette
In the summer my 06 auto runs around 200-202 coolant temp on the interstates at 75-80 mph. If I drop to 5th gear the temp drops to 196-198, but fuel mileage drops big time.
Even in city traffic the fan never lets the temperature go above 206-208.
Ed
Old May 29, 2009 | 01:41 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
Ed
Op is looking for Trans temps, not coolant temps
Old May 29, 2009 | 03:34 PM
Lil' Red Corvette
Well---in that case, it goes all over the place. But according to the facory service manual for 2006, at "286 degrees F for 10 seconds you will get a DTC of P0634. The TCM will shift to a default gear, shuts down, and turns off." It doesn't say what the default gear is. It is a type A code, and will light the MIL. (malfunction indicator light)
I personally have seen 260, but usualy around 210-230.
Ed
Old May 29, 2009 | 03:41 PM
mariomark's Avatar
mariomark
Thanks, I was getting a little worried, I haven't noticed my Yukon get that high while trailering. Though I might be misremembering...
Old May 29, 2009 | 04:08 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
About 180 is fine but no higher than 220 - 225 on very hot days over that the fluid can form varnish
To Heating Up
