Rear end
Old May 30, 2009 | 01:39 PM
VNVETT's Avatar
VNVETT
Default Rear end
When replacing break in lube for the rear end using a product such as Royal Purple Synthetic that already has the diff additives do you still have to put in the GM friction modifers????
Old May 31, 2009 | 03:21 AM
LS WON's Avatar
LS WON
I know Redline has the addictive already in it and I have no problems using that in my other car.
Amsoil does also but with the Amsoil you can add their slip lock so I have heard on here and people have had good results with the Amsoil and adding a tube 4 ounces of slip lock.
The new GM fluid Dexron L? gear oil recommends that you do not add any type of friction modifer to their fluid.
I have not heard much on the Royal Purple isn't it the new kid on the block as far as synthetics go?
Old May 31, 2009 | 04:48 PM
calemasters's Avatar
calemasters
No.
The factory differential does not have break-in oil that requires replacement after X miles. When it is time to replace the oil in the differential, I recomment the GM Dexron LS 75w-90. If do you choose to use the GM Dexron LS 75w-90 gear oil, do not add any additives.
Old May 31, 2009 | 04:55 PM
burtonbl103's Avatar
burtonbl103
St. Jude Donor '06-'07-'08,'12-'13
nope just use te royal purple !
Old May 31, 2009 | 05:44 PM
VNVETT's Avatar
VNVETT
Thanks guys, What I meant was I just put in a stage 2 RPM diff and they told me after 500 miles to put the 75/90 in and I bought the Royal Purple and want to know if I still needed to put in the additives from GM. I think I have my answer. Just put the Royal Purple in .
Old May 31, 2009 | 07:24 PM
LS WON's Avatar
LS WON
No Redline or Amsoil
Old May 31, 2009 | 07:49 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
For the C5, I'd say no, but for the C6 I'm not sure. In my 02 Z06 and my 06 CTS-V, I use the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 without extra additive and neither diff chatters. But with the C6 diff, it seems to need one extra bottle of friction modifier. Given that parallel, I'd assume, but don't know that the RP would as well. Easiest way to tell is to put it in without extra additive and drive it. If the diff chatters, add a bottle of additive.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jun 1, 2009 | 09:33 AM
KENZ51's Avatar
KENZ51
Im going with Royal Purple also, its got the additive already in it.
Old Jun 1, 2009 | 11:05 AM
LS WON's Avatar
LS WON
Redline already has addictive in it too.
Amsoil Severe Gear has it but you have the option to add more.
To Rear end
