Mild cam ?
Old May 31, 2009 | 09:49 PM
Night Stalker's Avatar
Night Stalker
Default Mild cam ?
I am looking for a mild cam for my 07 C6. I want it streetable yet I want the sound of a nice cam. Who offers a cam like I described that adds a lot of power and torque? Also should I change my valve springs? My car has about 1400 miles on it.
Old May 31, 2009 | 10:20 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
always do a cam kit..cam, springs & pushrods. You could probably run your original chain with your low miles if your cam isn't to aggressive but I will let the pro's take it from here.
I hope to swap out the cam in mine next year and will look to SpinMonster for advice based on my goals etc as I like his taste in cam only setup's for good power and driveability.
Old Jun 1, 2009 | 10:39 AM
Nightstalker Medic's Avatar
Nightstalker Medic
Here is what I went with:
I have the Whiplash Cam and love the crap out of it. See sig for the other things I did to my 07 too. Good luck with your cam selection. Make sure you get a new Cam Sprocket too. The 07 has a single bolt holding in your cam The new cam will come with three bolt holes.
Our cam package contains the following parts:
1 x EnglandGreen custom grind cam
1 x GM Front Cover Gasket
1 x GM Front Cover seal
2 x GM Waterpump seals
1 x GM Crank Bolt
1 x GM LS2 Timing Chain
1 x GM Oil pump pickup O-Ring
1 x High volume, high flow oil pump
1 x 160 degree thermostat
16 x Patriot Extreme (.660s) dual valve springs with titanium retainers
16 x 7.400 inch chromemoly hardened pushrods
1 x 25% underdrive crank pulley
1 x New serpentine belt
1 x tube of Red Locktite
Here are some of their cams:
* EnglandGreen Ninja Cam™ : brand new stealth cam with no chop at idle with an exceptional flat torque curve - wide intake/exhaust spread and LSA in the 118 range. No one will know that your Vette is cammed!
* EnglandGreen Havoc Cam™ : wreak havoc with our new creation cam in the high 220/low 230s duration range
* EnglandGreen Mayhem II Cam™ : formally our Mayhem Cam™, but now completely redesigned - and much larger! Duration is in the low 240s range.
* EnglandGreen Whiplash II Cam™ : Best Seller!! Duration in the mid 240s and extremely aggressive.
* EnglandGreen Chaos II Cam™ : formally our Chaos cam™, but completely redesigned and significantly bigger. Duration is in the low 250s
* EnglandGreen Black Rage Cam™ : Our latest creation. For use only in big cubic inch motors. Duration is in the high 250s/low 260s duration
* EnglandGreen Insanity Cam™ : This cam is for the seriously mentally disturbed among us. Duration is in the low 270s
Ask for Stephen or Jason
Phone: 281 464 2800
Email: sales@englandgreen.com
Old Jun 1, 2009 | 08:24 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Thanks for the kind words Walter.
Night Stalker, give us a call if we can be of any assistance.
Stephen
To Mild cam ?
