Injector Recommendation
Old Jun 3, 2009 | 11:01 AM
the1n_Only's Avatar
the1n_Only
Default Injector Recommendation
With my head and cam package about to go on, I'm pretty sure I'm going to be on the high side of duty cycle of the injectors. What do y'all think would be a good injector to go with? Keep in mind I want some wiggle room. In the near future I'm going to install a ported fast and a 150 shot
Old Jun 3, 2009 | 12:06 PM
HinsonSuperCars's Avatar
0HinsonSuperCars
Former Vendor
From: Birmingham, AL www.hinsonsupercars.com 205-909-9402
I would recommend FAST 46# Injectors $370
The 150 shot is wet?
Seth
Old Jun 3, 2009 | 12:08 PM
the1n_Only's Avatar
the1n_Only
Yeah, im looking at a plate kit
Old Jun 3, 2009 | 12:09 PM
IPS Motorsports's Avatar
IPS Motorsports
With no knowledge of heads stats, and cam figures. I would safely assume just grab some 60-65 lb/hr injectors. Those will safely support nearly all the power most heads cams swaps allow. They will also allow you to have the wiggle room, you need. (Dont neglect the pump in this instance, or think about a stand along fuel setup for the nitrous. Fuel pressure and flow are equally important as the possible flow of the injectors)
We use these often! PTE 60 lbers I can cut you a little member disounct at well!
http://www.ipsmotorsports.net/produc...oducts_id/2882
Good luck
-Brandon
Old Jun 3, 2009 | 12:37 PM
the1n_Only's Avatar
the1n_Only
I'm looking to do just the injectors right now, and when I put the nitrous kit on that's when I'll replace the fuel pump.... Unless when I get the car on the dyno am I'm still running out of fuel. I guess we will have to see.
IPS what kind of duty cycles are you usually seeing on a car that has 500 rear wheel horse power? Are you seeing any idle quality issues with the bigger injectors?
Old Jun 3, 2009 | 02:31 PM
Nightstalker Medic's Avatar
Nightstalker Medic
What are the size of the stock injectors on a 07 vette? Will the stock injectors handle roughly 500RWHP?
I plan on putting a set of TF225s on my car.
Would it be better to get the FAST 46# Injectors (LS2) or the FAST 57# Injectors (LS2) ?
Do I need to get this too?: MSD Fuel Pump Booster
See sig for the other mods already done to my car.
Old Jun 3, 2009 | 05:09 PM
the1n_Only's Avatar
the1n_Only
Nightstalker, it looks like we are in the same boat here huh.
Old Jun 3, 2009 | 06:05 PM
IPS Motorsports
The issue with duty cycles is they vary car to car, injector to injector, and then fuel pressure. I can tell you that on average with a 60 lb/hr injector on a 500 ish horsepower motor we see the 60% range I believe. Maybe higher maybe lower due to some variance, but again on average.
With the 42 lbers at 4 bar and 500 horse power I would bet your in the 75% range and above. We prefer to stay under 80-85% for safety measures.
I know this is somewhat vague, but that is the nature of the beast. If you would like to really calculate injector sizing, us RC engineering's injector calculator to get you your target size and duty cycles based on fuel pressure and other inputs.
If you would like anyone is welcome to call in give me as much information as possible and I can spec out your injector sizes on each case by case. No charge
-Brandon
Old Jun 4, 2009 | 12:12 AM
Nightstalker Medic
Yes, we are. I didn't even to about injectors!! Crap.
Old Jun 4, 2009 | 01:06 AM
SpinMonster's Avatar
SpinMonster
Originally Posted by Nightstalker Medic
Yes, we are. I didn't even think about injectors!! Crap.
I'll take care of the injectors when we swap out your heads. Its a tuning issue too and not just physically putting them in.
The manners of the motron 60's are awesome and they are easy to tune.
Let me know when you're back home.
Hope all is well in the desert.
Old Jun 4, 2009 | 08:52 AM
Nightstalker Medic
Spin, Thank You.
Hopefully I will be back around Jan 2010.
All is well here in the desert so far. It's getting old very quick here though.
Old Jun 4, 2009 | 10:36 AM
0HinsonSuperCars
Former Vendor
32-33 lbs. Your factory injectors will be pretty maxed out at that power level. Both sets would work fine for you, the 57's would allow plenty of room to grow if you need to. Your factory fuel pump should be fine.
Seth
To Injector Recommendation
