ZO6 Exhaust
Old Jun 7, 2009 | 11:41 PM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Default ZO6 Exhaust
Old Jun 8, 2009 | 12:21 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by RULEMKR
For those of you who have done the z06 mufflers on on a regular C6;
Are there any alignment issues or do they pretty much hang as normal?
I know the pipes have to be cut and re-welded but I was just curious
about hanging positions.
I would cut them flush (all 4 your 2 stocks and the 2 Z-06 cans) at the mufflers. Then add the Z-06's to your pipes.
Easiest with no hacked up look! Plus they hang exactly the same!
Old Jun 8, 2009 | 02:12 AM
nwc6's Avatar
nwc6
The guy that did mine left about a 2" stub on the Z06 mufflers, then tack welded the 2 1/2" over axle pipes from my stock mufflers to those stubs. This allowed us to move things a bit to get everything aligned..then he finished welding the pipes to the mufflers. The tips fit exactly like the stock tips, except they are a bit larger and fill the space up.
Old Jun 8, 2009 | 07:01 AM
SonOfDreams's Avatar
0SonOfDreams
Former Vendor
St. Jude Donor '09
the sets we have done hang the same. They cut the over the axel at the back of the muffler and installed a 2.5" female adapter so the stock over the axel could be installed and then tightened with a band clamp
To ZO6 Exhaust
