magnetic ride control question....
Old Jun 11, 2009 | 03:16 PM
texastim's Avatar
texastim
Default magnetic ride control question....
i was thinking about lowering my rear about an inch. since i have the magnetic ride control feature, would lowering the car (via bolts) have any adversive effects in it?
Old Jun 11, 2009 | 06:08 PM
VettedCandidate's Avatar
VettedCandidate
No...search is your friend.
Old Jun 11, 2009 | 07:23 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Maybe........search is your friend.
No one (that I've seen) has posted anything quantifying the SOTP result of lowering the F55 suspension.
There was a detailed thread with the technical explanation about how the system would be compromised, which was enough for me not to do it.
YMMV.
Old Jun 11, 2009 | 07:50 PM
texastim's Avatar
texastim
thanks everyone!
yep the little corvette voice in my head say's 'don't do it'.....besides, that might give obama a chance to void my current factory warranty if i were to do so!
Old Jun 11, 2009 | 09:26 PM
Knob Jockey
Originally Posted by texastim
thanks everyone!
I don't think it would affect the warranty because it's just an adjustment. You should probably use the stock bolts and not try to lower it too much.
Some members have done it without any major problem like Active Handling intervention.
The reduced travel of the shock changes the effectiveness of the MR manipulation.
You could try it and always set it back if you felt a "problem".
Old Jun 11, 2009 | 11:01 PM
Wayne O's Avatar
Wayne O
CF Senior Member
In my quest to modify the F55 suspension I became acquainted with one of the lead Delphi engineer's responsible for the F55 suspension in the Corvette (Darin Dellinger). The topic was more related to the question of repositioning the F55 sensors in a lowered car but it has some relevance to your question.
"...The position sensors do sense position, but internal to the MR ECU a calculation (differentiation) is made to turn that information into velocity - the rate of change of position with respect to time.
Very simplistically, I’ll say that velocity is really the main signal of interest, as many handling, stability, body and wheel control strategies use this basic information in various ways. Also, don't forget that dampers are velocity devices - even though we usually say the MR device is not really damper, but an actuator. Position is used, too but that information is only critical to a few control strategies. Of course, we have a strategy to do simple position-sensitive damping control, but it's not used in the Corvette.
In the end, regardless of where we're at in the suspension travel, it's the rate of change of the position signal over time that matters - that's why we don't have to change the position sensor mounting when lowering or raising the car.(emphasis added)
Almost everything for MR (sensing, processing, output control, etc.) is done at 1kHz or 1000 times per second.
The main reason I suggest cutting bumpstops is that "free suspension travel" is everything, in my opinion. (I'll define "free suspension travel" as the amount of travel of the shock absorber between full rebound and jounce bumper engagement.) When the car is lowered, compression travel is taken out. The jounce bumper is a secondary spring. It will engage even on relatively smooth roads (emphasis added)(I still remember "discovering" this fact on one of the access roads at the Desert Proving Grounds many years ago, during the course of developing the profile, length and hardness of the C5 jounce bumper). Also, and maybe most importantly, during turning events the jounce bumper may engage, leading to oversteer or possibly understeer - and sometimes we can be snookered into thinking the oversteer/understeer is coming from another source like the main suspension spring rate or the stab bar or tire pressures or ?? (another story: the CERV IV had terrible max lat numbers for some time. Everybody was really upset, because these numbers were really low. Turns out, the jounce bumper was simply too long in the rear. Spring rate goes up, traction goes down
Old Jun 12, 2009 | 12:26 AM
SlickShoes's Avatar
SlickShoes
_Sloth Whisperer_
Have it, did it, enjoying it.
My F55 C6 showed no discernable adverse characteristics after cranking my stock bolts all the way up into the leaf springs, far as they'd go. No error messages, no unexpected results.
I have a set of Pfadts on the way though, and will be using the Casper's F55 manipulators to keep the Active Handling nanny occupied. Allows me to return the car to fully stock should I decide to sell it F55-equipped.
To magnetic ride control question....
