What a let down....
Old Jun 12, 2009 | 06:01 PM
Bkbulldog's Avatar
Bkbulldog
Default What a let down....
I got the money for header , install and tune. So I was planing on having Texas speed install there headers and tune the car because I thought they did all this. So I call up there to see how much ever thing will be and the guy on the phone says they dont do exhaust installs. So let me get this straight , they made there brand of headers for the C6 and there sopes to be this good performance place and they cant install there own header wtf? Even if I buy the headers idk a good place in west texas to have it installed and tuned.
Old Jun 12, 2009 | 06:16 PM
Tony B4's Avatar
Tony B4
St. Jude Donor '08
I know Texas is BIG, but why wouldn't you give Lg motorsports a call?
Old Jun 12, 2009 | 06:18 PM
c6 batmobile's Avatar
c6 batmobile
Install it yourself. Its really easy and with the help of a friend you can do the whole exhuast from header to tail pipe in less than 4 hours. Ive done mine so many times now I can do the whole system in an hour. You have a ton of performance shops in texas. 21st century motorsports, lg motorsport, corvettes of dallas, england green I know there are more. Just save the install cash and buy another mod with it then take it to one of these tuners and have them put some pep in it.
Old Jun 12, 2009 | 06:20 PM
SL33PER's Avatar
SL33PER
I had LG do some work on my car. They were very accommodating
Old Jun 12, 2009 | 06:37 PM
Bkbulldog's Avatar
Bkbulldog
Im just really scared of messing somthing up trying to install myself.
Old Jun 12, 2009 | 06:44 PM
c6 batmobile
Um you really cant mess up. There are a few bolts on the manifolds which are really easy to get out. The cats can be diconneted from the h-pipe and removed as a whole with the manifolds. Just diconnect the )2 sensors firts. Then you have some clamps that hold the mufflers to the h-pipe which are also easy to removed. Then instead of pulling the mufflers out of the rubber hangers just remove the hanger all toghether. Then turn and slide the muffler pipes out if you have an auto you may have to cut the passenger side off about 4in. Then put them back in and dont forget your antiseize on your header bolts and reconnect your o2 sensors. Its really straight forward and extremly hard to screw something up. If you were in my area I would install them for you for just a six pack.
Old Jun 12, 2009 | 06:47 PM
Bkbulldog's Avatar
Bkbulldog
Hah idk I might look into it.
Old Jun 12, 2009 | 06:56 PM
c6 batmobile
You really should. It is not a hard install at all. Almost as easy as intalling a intake.
Old Jun 12, 2009 | 07:00 PM
Bkbulldog's Avatar
Bkbulldog
I found installing a intake to be a PITA.
Old Jun 12, 2009 | 07:18 PM
c6 batmobile
Ok maybe a bad example then. Its just some bolts. If you can turn a wrench and jack a car you can put headers in.
Old Jun 12, 2009 | 09:19 PM
Bkbulldog's Avatar
Bkbulldog
I decided against it I would rather have it done right =P
Old Jun 12, 2009 | 09:53 PM
ls3power's Avatar
ls3power
Alot of shops have stop doing work that envolves anything that affects the emissions on cars, there is a hefty fine for it.
Old Jun 12, 2009 | 09:55 PM
Bkbulldog's Avatar
Bkbulldog
Would they do it if they had cats?
Old Jun 12, 2009 | 10:29 PM
danl72's Avatar
danl72
Give them a call.
Old Jun 12, 2009 | 11:46 PM
rcmigpilot's Avatar
rcmigpilot
Moving the cats from their factory/EPA certified location is the issue, not cats/no cats.
Old Jun 12, 2009 | 11:58 PM
White_Lightning's Avatar
White_Lightning
Take it to LGM.. problem solved...
Old Jun 13, 2009 | 12:11 AM
Bkbulldog's Avatar
Bkbulldog
They will install catless?
To What a let down....
Old Jun 13, 2009 | 12:24 AM
White_Lightning
I would ask them directly. Louis, John and anthony from LG post on this board.. look for uses with @lgmotorsports in their name, they can answer all your questions.
Old Jun 13, 2009 | 01:02 AM
LS1LT1's Avatar
LS1LT1
Well in all fairness, my local butcher cuts/sells a really good steak too but he still doesn't come to my home and cook it for me.
Old Jun 13, 2009 | 01:07 PM
Corvettes of Dallas's Avatar
Corvettes of Dallas
Well let me throw Corvettes of Dallas into the mix.
Our performance shop is well equipped to handle your needs. And, if you prefer to install yourself -- we are here to help you accomplish the task.
We will glady walk you through the process. We have one of the best PERFORMANCE TECHS in the country and we will do what ever you need.
Todd
