Key Fob and Tech 2 question
Thanks for your help!
-Chris
This procedure will erase all known key fobs. The procedure will then program a single or multiple key fobs. It requires that you have a replacement key fob and a scan tool. Any known fobs should be removed from the vicinity of the vehicle.
Important: All previously programmed key fobs will be erased upon completion of the 30-minute programming procedure. The order in which the key fobs are programmed will determine its numbering position within the RCDLR memory. The first key fob programmed will be key fob #1, and the second key fob programmed will be key fob #2. The number stamped on the key fob case is for reference only: #2 can be programmed as #1.
Do not place any known key fobs in the vicinity of the vehicle when programming with Method 2. If the RCDLR recognizes a known key fob during Method 2 programming, the programming mode will resort to Method 1.
1. Using the scan tool access the following:
• Vehicle Control Systems
• Module Setup
• Remote Control Door Lock Receiver
• Program Key Fobs
2. Select Invalidate All Fobs. Press enter on the Tech 2. The Tech 2 will display: FOLLOW SI INSTRUCTIONS. Press enter on the Tech 2 to continue, then press the PROGRAM button. The DIC will display: OFF/ACC TO LEARN.
3. Press the OFF/ACC portion of the ignition button.
4. The DIC will display a message: WAIT 10 MINUTES. It will then count down from 10 to 0, one minute at a time.
5. When the timer reaches 0, the DIC will display OFF/ACC TO LEARN. Repeat steps 3-5 two more times, for a total of 30 minutes. The repeating of steps 3-5 must be done within 3 minutes of the timer reaching zero to prevent the exiting of learn mode. On the second and third sequence, the DIC will briefly display NO FOB DETECTED before transitioning to the timer. This is normal.
6. At the end of the 30 minutes, a beep will occur and the DIC will display: READY FOR FOB 1. At this time all previously known key fobs have been erased.
7. Place the replacement key fob in the glove box fob pocket with the buttons facing right.
8. A beep will occur indicating the fob has been programmed.
9. Additional key fobs can be programmed by removing fob 1 from the pocket and inserting fob 2. If desired, up to 4 fobs can be programmed. Once 4 fobs have been learned, the DIC will display a message: MAX FOBS LEARNED, and automatically exit the program mode.
10. If learning less than 4 key fobs, press the OFF/ACC portion of the ignition button to exit the program mode.
Important: Failure to press the UNLOCK button of each key fob will result in that fob being inoperative. Pressing the UNLOCK button finishes the programming sequence and is require to ensure transmitter operation.
11. Press the UNLOCK button of each key fob to finalize the programming and confirm system operation.
