Headers NEED tune?
Old Jun 17, 2009 | 10:33 AM
SgtRod's Avatar
SgtRod
Default Headers NEED tune?
I got LTs put on my car about a month ago. I have not tuned the cars since although I got a SLIGHT tune according to JF when porting my TB/Intake before the headers.
Also besides the intoxicating soud at WOT I didnt feel a big difference(like 20-30ish HP should)
Am I missing out on a LOT of horsepower and better drivability due to not having it tuned after my mods????
06 A6
Bullets
LG Pros w/cats
Ported TB/Intake
MSD wires
NGK TR55 plugs
ATI harmonic balancer comming soon.
Any comment would be greatly apreciated
Rod
Old Jun 17, 2009 | 10:38 AM
White_Lightning's Avatar
White_Lightning
do you NEED a tune? no.. for years people have done bolt ons and even heads/cams on f and y bodies with out any ecu tuning.
Is a tune optimal? sure.. you can pick up decent power from a tune but if you dont tune it the car will still run.. you can still drive it.
Old Jun 17, 2009 | 10:41 AM
SgtRod's Avatar
SgtRod
Thanks Lightning.
I guess what Im really asking is if Im missing out on a lot of HP and better drivability cause I didnt feel a big difference after adding the most powerful header on the planet.
Old Jun 17, 2009 | 10:48 AM
C6Manny's Avatar
C6Manny
Originally Posted by SgtRod
Thanks Lightning.
I have pretty much the same mods as you minus the wires and sparkplugs, and I gained an extra 20WHP just from the tune. It will make a noticable difference in power with the proper tune.
Old Jun 17, 2009 | 10:51 AM
White_Lightning
imo with anything that is a major change of air in and out it would be better to get a tune. That way you can really optimize the fuel usage and or adjust timing as needed.
i have seen some ppl gain 20 rwhp from and tune and some gain 2... really depends how your car was running with the stock tune. With tunes going for $400-500 if you dont mind spend the money go for it, but realise you could gain 5 rwhp. or you could gain 20 rwhp.
Old Jun 17, 2009 | 11:06 AM
BOB EAGAN's Avatar
BOB EAGAN
06 A6
Bullets
LG Pros w/cats
Ported TB/Intake
MSD wires
NGK TR55 plugs
Rod
A basic tune will usually give 5-10 hp with a few bolt ons. Since you are already tuned it will probably give you nothing. Your headers are worth 25 hp, a new tune will still only yield 25 total hp and the SOTP difference is small for that amount of hp. If you don't mind spending several hundred dollars, it won't hurt anything.
Old Jun 17, 2009 | 11:25 AM
C6Manny's Avatar
C6Manny
This is not always true, or at least it wasnt for me. I was in the same situation as the OP. At first I had a catback, K&N intake, ported Intake Manifold and TB by Jeremy Formato with a minor street tune. I then added headers and went back to Jeremy for a full dyno tune and gained an additional 20whp once the tune was complete. I understand this is not the norm, but you never know.
Old Jun 17, 2009 | 11:29 AM
SgtRod's Avatar
SgtRod
The tune I had was jsut a sample done while adjusting the cpu for the porting. The tunner stated that he barely did anything to it.. just a sample. I was spinning the RFs on the 1st to 2nd shift!
25hp shouldnt feel any different? If I understand how this goes, 25 on a dyno = more to the motor. I might be crazy but I noticed a difference when I added the Bullets.
Maybe every add on will go yielding less and less SOTP difference.
Maybe time for gears?
Old Jun 17, 2009 | 01:55 PM
BOB EAGAN's Avatar
BOB EAGAN
You will notice in my post I used the term usually and did so for that very reason. So that you will know where I'm coming from, if you take a cai @10 hp, lth@25 hp, ported intake@10 hp, electric water pump@ 6 hp, an u/d pulley@10 hp, a non ported fast @15 hp(bolt on only) a ported Fast @ 25hp(h/c), you can take any one , two, three or whatever number of these mod add them together and add 5-10 for a tune and you will be amazed how close you are to the dynojet numbers. Look at Tony B or Mike V. or my own numbers or Siefferts, look at almost anybody. Now if you do a cai and headers without a tune you should get 35 hp, but you may only get 25 on the dyno, and after the tune you should end up with 40. Question is did you get 5 or 15 from the tune? I don't know, by the way I figure it, it comes out very very close. Thanks for your coments.
Old Jun 17, 2009 | 02:08 PM
BOB EAGAN's Avatar
BOB EAGAN
My first mod was cai and Corsa Sports and a tune, gave me 365 rwhp, 07 m6. At 345 base I got 20 hp. Sounded better, maybe a little quicker, no big deal. SOTP change was not there. Second mod was LTH, heads and a cam which gave me 85 more to 450/405. Now the SOTP meter was in high gear, spun like hell in first and second, violently. Had to go to 325's in the rear to get it to hook up. Third trip was gears, 390's. WOW. Out of the hole to 7000 rmp is awesome. I'm going to need a shift light as I keep from hitting the rev limiter(set at 7000 rpm) It come up so quick. Maybe I just getting slow in my old age, but I sure like my car the way it is. Good luck to all oll of you.
Old Jun 17, 2009 | 02:19 PM
SgtRod's Avatar
SgtRod
Thank you Bob,
Not being smart, just trying to get to the info desired.
I know that HP doesnt tell the whole story though Tq management and tranny all may make the car FEEL and shift faster.
Also peek HP doesnt mean that there wasn't gains under the curve as well.
Im not a pro, just speaking on what I understand to be the possibilities.
Old Jun 17, 2009 | 02:21 PM
SgtRod's Avatar
SgtRod
I keep hearing gears are the sh*t and its starting to get the best of me. I have an A6 but wonder if It would make me happier/faster in my daily driver
Old Jun 17, 2009 | 02:32 PM
BOB EAGAN's Avatar
BOB EAGAN
Thank you Bob,
Didn't take it as being smart at all. We all learn from sharing and thats what make this such a good forum. About the best mod I've seem for under the curve performance is the ported Fast on a h/c car. I do not have the fast, but have read the reports and viewed the charts and it is awesome. I'm at the point now that the 325 F1 supercar tires will spin in less that 80 degree weather if I'm not careful. When these wear out, Toyo's or Nitto's and if the hold it'll be time for the Spinfast. TM is very helpful in the tune especially in auto's.
Old Jun 17, 2009 | 02:41 PM
BOB EAGAN's Avatar
BOB EAGAN
SGT ROD: I have not figured out how to post my dyno sheet, however if you look at TonyB4 's dyno, mine is almost an exact replica. I overlayed my sheet on top of his and was amazed how close they are. He has a few more hp and tq than I, but the lines just follow each other all the way up. Noticed your coment on the Bullets. Aftermarket exaust will add about 10 hp, and my gut feeling is because they were so much louded you got a better sense of the engines power. Bet it sounds great.
Old Jun 17, 2009 | 03:17 PM
SgtRod's Avatar
SgtRod
I have my stock intake and TB ported and I like that mod. If I had known how much I was gonna like it I would have gone with a ported Fast from the begining. If I do now Im throwing away the cash I spent on that unless someone on the forum wants it.
The bullets did make it louder but nothing compared to what the headers did.
Spinnig at 80mph?..wow, thats fun. Especialy since vettes are so easy to control. I dont have H/C on my car but the Invos and nt05s hook up great ! I have the Invos and it helped lots! I haven't taken it to the track since adding them or the headers but its deffinitly noticable
To Headers NEED tune?
