Rear End Noise
Old Jun 19, 2009 | 09:11 AM
LKicklight's Avatar
LKicklight
Default Rear End Noise
Just brought home a 2007 Z51 Coupe, MN6. The first time I backed out of my driveway, after a 700 miles cross country trip without any problems, this came as a shock. The first time you push the clutch in, put it in gear, then release the clutch gradually, no noise, when you push the clutch in a second time and let it out, that's when I get a " clink ", " clink " sound. Also, if you drive in a tight circle at a low speed you get some noise at that time also.
Does anyone have an idea, I am suspecting a Yoke " U " Joint....
lkicklight
Old Jun 19, 2009 | 09:28 AM
NYC6's Avatar
NYC6
Sounds like the differential issue. There is a TSB on it. The dealer will flush the oil out and fill with an oil which will correct the problem. Many here have had it, myself included.
Old Jun 19, 2009 | 09:36 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Check it out:
http://forums.corvetteforum.com/1570152115-post22.html
To Rear End Noise
