location: 034 Motorsport in Fremont, CA. 11am, around 70 degrees. Land and Sea Dyno
I didn't get a chance to really ask any questions, place was an audi/vw shop with a promotion going on that day. The runs were $55, so I figured why not. My friend went before me with his new (7k miles on the od) bone stock '09 Toyota Yaris which put down 77hp @5911rpm.
Is their dyno reading low or should I be heading to a shop to have my engine checked out?
From: Greater Detroit Metro MI, when I'm not travelling.
Originally Posted by WhiteLightning_
Dynojet? or mustang dyno?
DYNOmite... Says so at the top:
Looks incredibly low. My car put down the following on RPM motor's DYNOmite dyno with an intake, headers, exhaust and a tune:
Your car should be making between 340 and 360hp/tq at the wheels.
Does it feel wrong? It is entirely possible that the dyno was not calibrated properly or that the test was not conducted correctly... If it was my car I'd re-dyno elsewhere just to be sure.
I was wondering if their test had in fact been done correctly/properly. Doesn't even look like they brought the revs up past 6k before they let off on my chart. As for the feel of the car, I've riden/drove in several other stock vettes on many occasions, my dad having owned 2. I've felt nothing that would make me think there's anything wrong.
i have never seen a car dyno on that before so i dont know how it compares to say a dyno jet or a mustang dyno. I would go to a dynojet and see what it puts down. for all we know that brand of dyno could just read low...
The faster you run an acceleration test, the less horsepower ends up being indicated. Since that is a load bearing dyno, selecting a low load will give you low indicated power numbers...
Not saying they did that, but its a possibility.
Don't they have to input the weight of the car before running the test? Could be an easy way to fudge numbers. Numbers are no where near correct.
From: NJ..."the way I saw it, everyone takes a beating sometimes."
99% sure it's the dyno/operator. The Corvette plant would have to really f*ck something up to have your car dyno 50+rwhp less than every other mass produced C6. You would certainly feel a 50+rwhp difference between your car and your father's or whomever elses' you've driven. You say the car is running fine so unless you want to dyno elsewhere for simple peace of mind, you can throw out these results and just enjoy your car.
Originally Posted by Barberi
What gear did they run the dyno in?
Also, i have never heard of a "dynomite" dyno and would be leary of using one with very little known about it.
You may not be familiar with it, but it is actually one of the better dynos out there; it combines a large inertia load with an eddy current absorber.
Like any other dyno, it is just a tool, and it can be used improperly. But there is nothing wrong with that make of dynos; someone probably paid around $80,000 for it.
If all you want is a high number on a dyno sheet, just tell the operator what you expect ahead of time. He'll make it happen.
If you are tuning or needing a baseline before mods, let the operator know that too. Be sure to return to the same place to get comparative results. Don't be concerned with the resulting numbers, but only with the changes.
