Engine Knocking loudly: need ideas
Old Jun 22, 2009 | 12:11 PM
N2O4YOU's Avatar
N2O4YOU
Default Engine Knocking loudly: need ideas
My engine started knocking loudly the other day. I drove leausurely to work all was well. Started-up and sounded horrible when trying to go home. Oil pressure is perfect, no codes, sounds like a rod is trying to come through the block though. It seems like it gets better at certain rpm's when in gear, power seems ok but didn't hit gas hard. Checked all pulleys and for anything loose. Maybe a clutch problem? Any ideas would be great before I have to remove engine or drivetrain to troubleshoot.
Old Jun 22, 2009 | 12:27 PM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
In my experience it has been either rod knock (spun rod bearing) or piston slap (cracked ringland or similar piston damage). Rod knock seems to get better at certain RPMs... I would:
1- Change the oil and inspect it carefully for metal shavings.
2- Purchase a mechanic's stethoscope and identify which cylinder that noise is coming from.
3- Pull the ignition wire or fuel injector plug from that cylinder and see if the noise quiets down. If it does, you've found your problem cylinder.
4- Run a compression test. If one cylinder is down, run a leadkdown test to figure out where the compression is being lost.
5- Start figuring out where I want the engine rebuilt.
Is your car modded?
Old Jun 22, 2009 | 01:38 PM
Motorhead-47's Avatar
Motorhead-47
Originally Posted by PowerLabs
Is your car modded?
With a screen name of "N2O4YOU" I'm guessing the answer is yes it is mod'd..maybe I'm wrong but I think I'd win a beer on the bet....
Old Jun 22, 2009 | 03:04 PM
MARSC6's Avatar
MARSC6
My brother who is a mechanic calls that noise the death rattle. If the noise is coming from inside the engine prepare for an engine rebuild or replacement.
Old Jun 22, 2009 | 04:00 PM
N2O4YOU's Avatar
N2O4YOU
Thanks for input. Car is head/cam, etc... close to 500 rwhp. I will check and see if I can isolate.
Old Jun 22, 2009 | 04:07 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
you can goto church and pray its bad gas!!!
Old Jun 22, 2009 | 04:09 PM
c6 batmobile's Avatar
c6 batmobile
Sounds like a spun bearing. Forged internals are in you near future.
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
that IS possible carl...
Old Jun 22, 2009 | 04:29 PM
PowerLabs's Avatar
PowerLabs
Might be valvetrain related too... Bent pushrod, bent valve... Again, get the stethoscope and start troubleshooting. If it was my car I'd be posting compression test results by now and calling up some shops for price quotes...
Old Jun 23, 2009 | 12:05 AM
Spying Beast's Avatar
Spying Beast
Not laughing at your situation, but I found that comment funny.
Good luck.
To Engine Knocking loudly: need ideas
