Drone reduction trick
Old Jun 24, 2009 | 08:31 AM
Katech_Zach's Avatar
Katech_Zach
Premium Supporting Vendor
C7 of Year Finalist (track prepared) 2019
Default Drone reduction trick
I found a little trick for reducing the drone inside the cabin. I dynamatted the heat shield above the mufflers. The customer whose car we did this on has a dynamatted interior and he said the drone reduction from doing this was another step equal to the reduction when we dynamatted his interior. The combination has significantly reduced drone. Dynamat is resistant to heat up to 350 degrees. This shield is spaced a considerable distance away from the mufflers so it should be able to withstand the heat. Here is a pic.
__________________
Contact:
(e) zach@katechengines.com
Old Jun 24, 2009 | 08:43 AM
NYC6's Avatar
NYC6
I wonder how hot the cats,pipes and mufflers actually get? And what if the dynomatt works its way loose and falls directly on the exhaust? Looks promising though.
Old Jun 24, 2009 | 08:58 AM
commando57's Avatar
commando57
I have found the easiest way to reduce drone is to accelerate!
Old Jun 24, 2009 | 09:00 AM
Katech_Zach
The mufflers probably get 150-200 degrees in street driving conditions. This shield is 4-12 inches (depending on where you're measuring from) from the mufflers. If it were to come loose it would fall out the back of the car due to the angle of the mufflers. We'll try it on this one and see how it does.
More feedback from the customer in the Z06 section
http://forums.corvetteforum.com/c6-z...ion-trick.html
Old Jun 24, 2009 | 09:08 AM
GaryW's Avatar
GaryW
You took the words right out of my mouth
Old Jun 24, 2009 | 10:03 AM
Shrike6's Avatar
Shrike6
Somba master
Cruise-In 7, 9 & 12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '07-'08-'09-'10-'11
Would it be possible to sneak this in there without having to remove the mufflers?
GM
Old Jun 24, 2009 | 10:04 AM
Katech_Zach
GM
I think the better question is, can you get the muffler heat shield out without removing the mufflers? It's much easier to do this with the heat shield on a table. I would say that it is nearly impossible to do cleanly in the car. You also need to make sure the thoroughly clean the surface so the Dynamat sticks.
Old Jun 24, 2009 | 10:26 AM
rednred's Avatar
rednred
What about putting it on the upward side of the sheilds (between shield and body)? That would eliminate worries of it somehow contacting muffler.
Old Jun 24, 2009 | 12:56 PM
Ben Diss's Avatar
Ben Diss
Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
I did this as well and measured zero reduction in cabin sound level. I applied two layers of Dynomat to the heat shield.
FYI, I attached a SPL meter to the analog input of my HP Tuners interface and logged various driving conditions both before and after. Each test was within 2-3 db of each other.
No difference.
Old Jun 24, 2009 | 06:34 PM
Leprkon's Avatar
Leprkon
I've had RaaMat on mine for almost a year now, and it hasn't fallen off. That being said, on the installs for two friends, we pulled the plate and put the mat on top, just to be sure.
Once the plate is out, ten or fifteen minutes of work, tops.
Old Jun 25, 2009 | 01:29 AM
TinSecondRice's Avatar
TinSecondRice
St. Jude Donor '08-'11
No difference.
But, isn't 3 db double the sound?
I thought about doing this when I just had my rear out, but I didn't have any on hand and was in a hurry to get it back together.
With my new 3.42 gears, it make the drone right at 55 (the speed limit where I drive most). I ended up making the transmission wait and shift into 4th and lock up the converter about 60
Old Jun 25, 2009 | 06:40 AM
Ben Diss's Avatar
Ben Diss
When you're talking 90-110 db, 3 isn't noticable. FYI, I was running B&B Rt. 66 at the time.
To Drone reduction trick
