Carbotech performance brakes
Old Jun 25, 2009 | 04:33 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default Carbotech performance brakes
We take you deeper into the corners & across the finish line first.
When you want the control and modulation to take your track-bred car deep into the turns, you need unsurpassed Carbotech brake technology. Going deep before you brake allows you to stay on the accelerator longer going into the corner and even faster coming out.
If you're a professional racer, or if you're taking your street car to the track for club events, Carbotech has the best braking solution. That's why we are becoming the #1 manufacturer of performance brake pads around the world with professional and club racers--everyone who demands the best. At Carbotech, we've been heavily involved in club and professional racing for more than 17 years. We know what you need to win.
Smarter construction.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are "rotor friendly," eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
Custom solutions.
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call and we can recommend the compounds that will be perfect for your front and rear pads and shoes, assuring that they perform together with optimum effectiveness
Old Jun 26, 2009 | 06:40 PM
Keith N's Avatar
Keith N
I recently purchased the Carbotech Bobcat brake pads for my C6. They work great with virtually no brake dust.
Old Jun 27, 2009 | 11:31 AM
Carbotech Adam
Supporting Vendor
Thank you
Old Jul 1, 2009 | 04:21 PM
Carbotech Adam
Supporting Vendor
Lapping/Track Days
Go Deeper Into the Corners on Lapping Days!
When you take your car to the track, you want to know you can charge aggressively into the corners and be sure your brakes will shear off that speed—giving you maximum control without unnecessarily sacrificing pace. Just call us and our racing specialists will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly friendly to your rotors.
Old Jul 1, 2009 | 07:12 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Originally Posted by carbotech adam
Thank you
Are Bobcat's the 1521 pad I've read about?
Old Jul 1, 2009 | 07:43 PM
Keith N's Avatar
Keith N
Dark - I purchased them at IPS Motorsports (CF Vendor). They had good prices and free shipping. Here is a link - http://www.ipsmotorsports.net/produc...oducts_id/2588
Old Jul 1, 2009 | 07:46 PM
NavyC4S's Avatar
NavyC4S
St. Jude Donor '09
are your pads good for the street too?
Old Jul 1, 2009 | 09:57 PM
///DarkSide\\\
Thx Keith
Old Jul 2, 2009 | 10:06 AM
Carbotech Adam
Supporting Vendor
yes, the bobcat 1521 is the street compound.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
Old Jul 2, 2009 | 11:00 AM
PowerLabs's Avatar
PowerLabs
From: Greater Detroit Metro MI, when I'm not travelling.
I've been running Carbotech brakes on my car for a few weeks now; the stock pads felt real funny coming down from mid 170MPH (inconsistent brake pedal feel and pad bite) so I decided to upgrade into something more agressive; as per Carbotech's recommendations I've got XP8 up front and AX6 on the rear.
The bite is incredible! It actually took a little while to get used to how hard the pads grabbed and ABS kept on coming on the first couple of times I took the car out untill I relearned how much pressure to apply to the brakes.
Another big advantage was that, since Active Handling works by modulating the brakes, it has become much more effective at catching the car when it begins to slide (a common occurence with 600RWHP )
The one downside is that they squeal very loudly when coming to a stop (tried them both with and without shims, using anti squeal compound and plenty of caliper grease both times). Can't have everything I guess.
This is the 3rd vehicle I'm running Carbotech pads in; I think they make the best pads on the market and wouldn't use anything else
To Carbotech performance brakes
