Adding Vortech Supercharger to Cam / Headers / PI / TB Setup
Old Jul 8, 2009 | 03:09 PM
TBonez's Avatar
TBonez
2005 Beast
Default Adding Vortech Supercharger to Cam / Headers / PI / TB Setup
Guys,
What kind of numbers do you see me pulling by adding the Vortech supercharger to this setup:
Melrose Headers
Vararam CAI
Custom Grind Camshaft (580 intake, 225 duration, 590 exhaust,229 duration, 114 lobe seperation)
.650 Lift Duel Springs w/Titanium Retainers
New Valve Seals and Keepers
7.400 Hardened Pushrods
New Cryogenic Timing Chain
Oil Pump Is Rework For Higher Pressure
New Timing Cover Gasket and Seal
Amsoil Oil Change w/Filter
New Coolant and A/C Refrigerant
New Harmonic Balancer Bolt
160 Deg Low Thermostat
PCM Performance Tune w/Read Out Springs w/Titanium Retainers
New head gaskets
Ported Intake and TB
She has perfect street manners now, meaning it was tuned for that but numbers could be much higher with a more aggressive tune. This car is a semi-daily driver but current numbers are 440rwhp 415rtqe
Wondering what kind of numbers I could see by adding the Vortech, which is already on order I may add lol.....
Thanks,
Bonez
Old Jul 8, 2009 | 03:40 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
640/550 to the wheels. if you have to still pin the crank, swap out that cam to a blower cam. superchargers like a wider lsa, give andy a call and pick one up!
Old Jul 8, 2009 | 05:35 PM
Fore58's Avatar
Fore58
I didn't know that a C6 could make that much hp at the rear wheels. It's more than the ZR1, which is between 500-550rwhp in stock form.
To Adding Vortech Supercharger to Cam / Headers / PI / TB Setup
