Time for new pads..
My main reason for the swap was to eliminate the tremendous amount of brake dust the stock pads seem to give off. These did the trick and have comparable braking performance to the stockers and no noise.
If you want to do it yourself, it's not a big job. I think there are a few DIY write-ups on here.
Just to give you an idea of what things look like under there follow along with the link below - except that you will not have to tear down this far. IIRC I think if you remove 1 caliper bolt you can then rotate the caliper out of the way and get at the pads....I don't remember if that's true both front and back but regardless, if you need to remove the caliper you just take the other bolt out. Doing it yourself will save you about $500 from what you quoted
LINK
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
LINK
I put on the Delco Durastop Ceramic pads about a year ago only for the brake dust issue. Easy to DIY and they are completely quiet; not that my stock ones were noisy at all either. Easy job and just a tiny bit of dust as compared to stock pads. If you track your car, these might not be the best pads though.
