Low oil Temp?
Old Jul 12, 2009 | 09:40 PM
AlexVette505's Avatar
AlexVette505
Default Low oil Temp?
when im driving around and i check the oil temp its says "low oil temp". anybody else have this problem? whats wrong? maybe the sensor is broke?
Old Jul 12, 2009 | 10:17 PM
NYC6's Avatar
NYC6
Never saw that on my DIC. When started cold is gives the oil temp which slowly rises to whatever temp it is currently. I live in NY and on nice days take it out in the low 30's. Maybe someone else can offer more.
Old Sep 29, 2011 | 12:05 AM
n_brio's Avatar
n_brio
have you solved the problem? i have the same problem now :/
Old Sep 29, 2011 | 02:41 AM
Rebel 1's Avatar
Rebel 1
What is your coolant temp? If it's low sounds like a stuck open stat.
Old Sep 29, 2011 | 10:54 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
IIRC, that message appears if the oil temp is below certain (very low) number. In Sweden, could be accurate. In Maryland, could be a malfunction of the sensor.
At least, that's how it worked on the C5. I saw the message several times during each Chicago winter.
But haven't seen it on our 2006 or 2009, so maybe something is different.
Old Sep 29, 2011 | 11:34 AM
REVAK's Avatar
REVAK
Oil temp is directly related to coolant temp. Check coolant temp first. Oil temp in normal street operation should be around 30 to 35 degrees above coolant temp.
Old Sep 29, 2011 | 12:07 PM
timd38's Avatar
timd38
I have a Z07 radiator and a Z06 oil cooler and water is 190 and oil is 210 on an a mid 80's day in traffic. So my gap is about 20 degrees. I may have over killed on the oil cooler.
Old Sep 29, 2011 | 04:02 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Not at all.
If we can keep the GT2 car running 180-190 water temp and 230-240 oil temp for 24 hrs that would be ideal.
There is always going to be a 20-30 degree split between the two in almost every case.
As for the low oil temp reading, is that all it says or does it give an actual number if you scroll through? If it doesn't say anything then my guess is that the sensor is bad or the wiring to the sensor has a cut in it.
To Low oil Temp?
