Active Handling
Old Jul 15, 2009 | 05:35 PM
Astronomer's Avatar
Astronomer
Default Active Handling
I know this has been addressed many times here, but I have an intermittent problem (about once every 5 days or so as this is my daily driver) that I believe goes beyond just the steering column issues (that I already had fixed).
First I see - service "Antilock Brakes", then service "Traction Control", and finally service "Active handling" on the DIC which then continues to cycle thru those messages non-stop. Simultaneously both amber lights in my dash will light up and stay lit until I turn off and restart the car.
This all happens within a few seconds. Also, I see just the active handling is active on the DIC quite often these days. My dealer did a quick scan on the car and informed me the car was OK.
Any ideas? Thanks in advance!
05 F55 automatic Coupe
Old Jul 15, 2009 | 07:51 PM
haljensen's Avatar
haljensen
Have you changed from stock wheel/tire sizes?
Old Jul 16, 2009 | 01:58 AM
Astronomer's Avatar
Astronomer
Not at all. I am even using the same GY tire brand/type that came with her from the dealer.
This problem started this spring right about when she turned over 60K miles.
Old Jul 16, 2009 | 09:06 AM
SgtRod's Avatar
SgtRod
Just as I suspected, no one with an answer. IMHO Active handling /electrical is the corvettes biggest flaw.
I have similar issues with that and NO ONE (including 2 dealers) could figure them out.
Good luck and keep us posted
Rod
Old Jul 16, 2009 | 12:17 PM
Bill Suttie's Avatar
Bill Suttie
Have your dealer install an in flight recorder so the problem can be recorded when it happens. four incidents can be recorded on the unit. A lack of communication between computer modules could be the problem, the recorder will note it. Good Luck.
Old Jul 19, 2009 | 03:54 AM
Astronomer's Avatar
Astronomer
Wow! I did not even know such a thing existed. THANKS!!
I will have it installed. Will let you all know what I find. :-)
Old Jul 19, 2009 | 03:55 AM
Astronomer's Avatar
Astronomer
Rod
Sure seems like a big issue for lots of folk. And my Vette is now over 60K so if anything goes wrong it is on my dime. Sigh.
I will let you know ASAP if I come up with an answer.
Old Jul 19, 2009 | 06:29 AM
billcar9999's Avatar
billcar9999
Take a look at these threads. This one describes my problems (post 23) with an 06 convertible with F55. Your description sounds a lot like what I saw when running the data recorder.
http://forums.corvetteforum.com/c6-z...age-again.html
This one (post 13) is about "random" messages that may apply if you get other status messages that are not active handling or traction control related.
http://forums.corvetteforum.com/c6-z...post1570203696
Old Jul 19, 2009 | 07:07 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
My '01 C-5 used to give those messages occasionally. Problem was corroded or defective connectors where the wheel sensors connect to the wiring harness.
I'd pull the wheels, examine the connectors, and use silicone grease on them. Might solve some of these problems.
Old Jul 19, 2009 | 05:03 PM
2006c6keller's Avatar
2006c6keller
Default Clean first, then dialectic grease!
Use electrical contact cleaner before using dialectic grease (get from auto parts store, used in distributors, etc.). You can get contact cleaner from Lowes in the electrical department, this is made for cleaning electical contacts and is UL approved, etc.
Old Jul 19, 2009 | 05:39 PM
naschmitz's Avatar
naschmitz
I had the same issue with my 2006 C6. Every once and a while I'd get yellow lights and DIC messages. The dealer was able to find a fault code that led them to replace a wheel speed sensor connector. Problem fixed and never came back.
Old Jul 24, 2009 | 04:43 PM
Astronomer's Avatar
Astronomer
WOW! Thanks everyone. Sorry for being gone so long. I still need to take it in but now I have an idea where to start.
This forum and all you guys rock!
To Active Handling
