DOT3 or DOT4
Old Jul 24, 2009 | 02:03 PM
EuroVette07's Avatar
EuroVette07
Default DOT3 or DOT4
I was going to change the fluid in my clutch and I went and bought some DOT4 fluid as it has a higher temp. The clerk at the parts store told me to ensure that I drain all the DOT3 fluid out as the DOT4 is not compatible with it, it will gel up. Has anyone heard of this or can shed some light on the compatabilty of the two.
Old Jul 24, 2009 | 02:09 PM
95blklsc's Avatar
95blklsc
All the ones I have seen are 100% compatable. It will usually say on the bottle as well.
Old Jul 24, 2009 | 02:20 PM
Ranger's Avatar
Ranger
Suggest you read the label on the can. It should state what it's compatible with.
Generally store clerks are pretty clueless on such matters. Better info is from owners on the CF.
C6 owner's manuals state use DOT4 brake fluid in the clutch. So unless you've gone to something else, you've got GM-brand Super DOT4 in the hydraulics from the factory.
Ranger
Old Jul 24, 2009 | 03:05 PM
rws.1's Avatar
rws.1
Every DOT 4 I have seen is compatible with DOT 3
Old Jul 24, 2009 | 04:18 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
My 08 came with DOT4 clutch fluid, your car also should already have DOT4 from the factory unless someone F'd-up during the cars life.
Old Jul 24, 2009 | 04:51 PM
johnodrake's Avatar
johnodrake
Moderator
You can use DOT 3, 4 or 5.1 You cannot use DOT 5 (Silicone based).
Old Jul 24, 2009 | 05:04 PM
ETW's Avatar
ETW
I used Prestone DOT 4
Old Jul 24, 2009 | 05:56 PM
GregC6's Avatar
GregC6
just got a can of GM super dot4 for 7 bucks at the dealer gonna use the ranger method to clean it up
To DOT3 or DOT4
