Awesome, thanks for the pics along the way. Were there a lot of reusable parts after the fire? Did the heat from the fire weaken the strength of the frame at all?
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
A lot of parts are able to be re-used. The wiring, and plumbing suffered the worst of the fire.
The fire did not last that long, and pretty much just messed up the paint on the frame, nothing bad enough to harm the steel. Because of the nature and cost of the car, it is being stripped all the way down, cleaned and re-painted.
Originally Posted by CMY SIX
do you know what caused the fire? boy! thats quite the mount for the spoiler!
The fire was caused by the BMW hitting Boris in the passenger side. After a few laps (only about 6 to go) the exhaust had caught the body work on fire, and led to the fuel system going next.
A lot of prep going into this week's photos.
To give you an idea the floor of these cars has to be completely flat, we are given roughly a 5mm tolerance from this. You can see this in the pictures below as we string the car front to back and pick points along the floor before mounting.
To cut down on heat we are going a few more steps and covering the firewall with Ti, and it will be covered in gold just like the tunnel of the car was as well.
Friday 8-21-09 Update
She started last night (Louis will have video today). It should be sitting on it's tires by tonight and then concentrating on cleaning up the remaining hoses and wires so this weekend the body can go on for good and the car can get a complete polish and wax.
Side Pipes with Mufflers going on
Front Splitter and Radiator assembly
Brake duct hoses
Rocker Panel installed
Under Hood Plumbing complete
Under Engine Plumbed
Transaxle installed for final with fuel cells.
8-23-09 Update
Saturday night. All systems go. Car runs, drives and is now on the dyno. Tomorrow final detail and systems check. Body detail and mounting tomorrow after noon.
Rear suspension going together
Ready for air boxes
Air boxes on, Notice the tiny restrictors
Rear suspension, fueling, wiring, tires on!
Passenger side compartment detail
On the Dyno
Other than that...it's late and I will see you all on here tomorrow...then in Carlisle in just a few short days.
