Harmonic balancer LS2 (2006)C6
Sorry but you are going to have to eat the repair unless you got some kind of extended warranty. The TSB was about the center bolt of balancer coming loose. You have a failed rubber flexible coupling between the two rotating masses of the balancer. There was never any TSB or recall for that failure mode. Mine failed at 19,000 miles and for me was replaced under the original warranty.
I wish there would have been a recall and I would like nothing more than to drive over the person responsible for this who decided not to recall it multiple (times with the vette) then proceed to place their body into an over-sized industrial strength microwave oven.
Took the car to the local dealer to have it checked over and paid $100 to have corvette tech make sure the car was solid. They didn't find anything. I put the car away for the winter shortly thereafter and about 1000 miles or so later, the car had a squeaky belt that has since gone away, but the balancer looks wobbly. Shouldn't the tech's have looked at this when I brought it in the first time since it was a TSB and I was paying them to look things over. Now the car is out of warranty and I don't feel like I should have to pay for this since they should have caught it. Thoughts?
edit...What year? If '05 see the note below at the end about the recall.
Technical Service Bulletin
If they were knowledgeable of the "wobbly" HB problem, which BTW has been on every LS Corvette engine since 1997 when the C5's arrived, then yes they should have noticed it.......If of course, the problem was observable then. Who knows, maybe it aged a bit more over the winter and now went bad. IMHO....You really can't prove it, so it'd be a tough one to call them on it. You could try, but I doubt they'll agree to a $1k+ mistake.
Either way, it needs to be corrected or it could get worse.
But....I just thought of something. What's your vin#. There was a GM Recall on early LS2's because the bolt was improperly torqued. If you check in the FAQ section there's a thread about this with the VIn # range. If the bolt is loose, and your car is in the range, you may get it under the Recall notice.
Rich
What is your year and vin #. Did you check the FAQ section for the vin# range with the Recall for the loose bolt issue?
I'm in the middle of a tedious task on a '61 restoration and can't check right now. If you can search there see if your car is in the range, if it's a '05.
Rich
