Manual trans fluid recommendation
Old Jul 24, 2009 | 08:38 PM
timd38's Avatar
timd38
Originally Posted by nwc6
I used Redline D4ATF in my 08 for the cold 1-2 notchy shift. Maybe a 10% better shifting cold. Feels really good once warmed up.
I use Redline also.
Old Jul 24, 2009 | 08:48 PM
GregC6's Avatar
GregC6
i used redline in my old nissan with bad synchros, synchros fixed themselves and car drove perfect for next 5 years, that was with mt90 but that is gear oil...
Old Jul 25, 2009 | 05:02 PM
Ragtop 99's Avatar
Ragtop 99
I think I may try Redline. RP seems to be hit or miss based upon posts here.
I just skip 2nd gear for the 1st 10-15 minutes
Coming out of my neighborhood, I turn on to a moderately busy street heading uphill. If I skip second I'm revving first gear higher than I want on a cold motor. I skip second after for a couple miles (or double clutch) but it is annoying to remember.
Old Jul 25, 2009 | 07:34 PM
1953 C6's Avatar
1953 C6
I replaced mine today with Redline D4ATF after 10,000 miles and I would agree 10% improvement.
Old Jul 25, 2009 | 11:27 PM
Bludog's Avatar
Bludog
Originally Posted by Ranger
I run the manufacturer's specified GM-brand fluid in my transmissions.
I tried some aftermarket fluids three Corvettes ago and found the shifter feel changed in ways I didn't like.
So stock fluid is what I recommend. I do change mine at 8k-10K intervals because I track the car.
Equally important to tranny performance is keeping the clutch fluid clean so that the clutch hydraulics behave normally.
Most tranny issues flow from
(1) mis-behaving clutch
(2) driver error during shifts, including power-shifting synchronization issues
(3) wasted tranny fluid
I've had zero tranny issues racing three Z06s.
Ranger
Thanks for the info Ranger. I have been considering changing the trans fluid to Amsoil, but have not got around to it. 14,000 miles on the car, and I will flush with the recommended GM fluid. You gave me expert advise on launching the car and taking car of the clutch fluid, and although I don't track the car as much as you do, I will be changing the fluid asap. Do you have any tips on changing your trans fluis?
