Manual trans fluid recommendation
Old Jul 22, 2009 | 01:41 PM
GregC6's Avatar
GregC6
Default Manual trans fluid recommendation
Looks like the majority is running AMSOIL ATF or Royal Purple
Any other recommendations?
Do the shifts get smoother with new fluid?
Thanks,
Old Jul 22, 2009 | 01:57 PM
steveb601's Avatar
steveb601
I tried Royal Purple and I didn't notice smoother shifting. So I went back to the GM fluid since my car is still under warranty and I didn't want any problems if I had a failure.
Old Jul 22, 2009 | 02:32 PM
Motorhead-47's Avatar
Motorhead-47
I can recommend NOT installing Mobil 1 Synthetic in the transmission if you are looking for improved shifts. It made virtually no change in driveability and thinned my wallet by about $30.00 in my 2009 C6. It was a waste of time and energy.
Old Jul 22, 2009 | 04:31 PM
nwc6's Avatar
nwc6
I used Redline D4ATF in my 08 for the cold 1-2 notchy shift. Maybe a 10% better shifting cold. Feels really good once warmed up.
Old Jul 22, 2009 | 05:04 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
I put some AMSOIL Univeral ATF and am NOT impressed. apparently there is a New formula out there thats supposed to be better and sold under the same name. i guess i got shipped the old shyt! GRRRR.. going back to the GM stuff soon.
-carl
Old Jul 22, 2009 | 05:32 PM
GregC6's Avatar
GregC6
good info guys, anyone else wants to throw in their $.02?
Old Jul 22, 2009 | 08:50 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Amsoil ATF and NOT the newer formula, use the regular ATF.
Old Jul 22, 2009 | 09:22 PM
JayplaySS2's Avatar
JayplaySS2
Royal Purple in my KB Cobra since the trans was terrible... after about 2-3K miles, it was amazing (no difference just after swap). You would never know there was a problem on 2nd and 3rd. The 1st thing I will do with my next M6 C6 will be RP fluid.
Old Jul 22, 2009 | 09:59 PM
GregC6's Avatar
GregC6
is this the one you used?
Old Jul 22, 2009 | 10:31 PM
VET4LES's Avatar
VET4LES
I'm sticking with the GM fluid. I've found that the shifting has improved as it gets older. I have four years left on my GMPP and don't want to cause a problem if I need to use it.
Old Jul 23, 2009 | 07:26 AM
REVAK's Avatar
REVAK
Thanks,
I'm using Royal Purple Syncromax. Significant overall improvement. Gets better after some miles , as with any fluid in these transmissions, shifting is better after warm up.
Old Jul 23, 2009 | 02:16 PM
JoesC5's Avatar
JoesC5
I tried the RP and it made the condition worse. I drained it and put in Mobil syn ATF. After the change to the Mobil, I couldn't really tell the difference between it and the factory fill, maybe a little better when the transmission was cold.
Some have reported that Redline ATF helped, but I haven't tried it. Will most likely try the Redline later on. I now have about 5,000 miles on my 09 Z06, and the shifting has improved a little, but still not like it should be. Sunday I had my 56 out that I have a '70 Muncie WR 4-speed(with a Hurst shifter, and a repro handle) in it. The Muncie is louder then the Z06 but it shifts about the same but smoother then the Z06. The Muncie dosen't nibble or grind when shifting.
Old Jul 24, 2009 | 06:38 AM
crainholio's Avatar
crainholio
For a street car, Castrol cheap stuff at $12/gallon is my favorite. Very smooth shifting at operating temps, slightly notchy shifting below 40degF but I haven't found a fluid that isn't.
For a street and track car, Amsoil TorqueDrive is my new favorite. It wouldn't hurt anything but your wallet to use this fluid on the street, too.
Old Jul 24, 2009 | 08:14 AM
JayplaySS2's Avatar
JayplaySS2
Nope, it was the Synchromax, not ATF. I should have been more specific. It worked with in a few months and again, it will be the first thing I add to my next C6/C6Z. My Cobra took just over 2 bottles if I remember correctly.
http://www.royalpurple.com/manual-tr...ion-fluid.html
Old Jul 24, 2009 | 12:10 PM
Ranger's Avatar
Ranger
I run the manufacturer's specified GM-brand fluid in my transmissions.
I tried some aftermarket fluids three Corvettes ago and found the shifter feel changed in ways I didn't like.
So stock fluid is what I recommend. I do change mine at 8k-10K intervals because I track the car.
Equally important to tranny performance is keeping the clutch fluid clean so that the clutch hydraulics behave normally.
Most tranny issues flow from
(1) mis-behaving clutch
(2) driver error during shifts, including power-shifting synchronization issues
(3) wasted tranny fluid
I've had zero tranny issues racing three Z06s.
Ranger
Old Jul 24, 2009 | 02:19 PM
Ragtop 99's Avatar
Ragtop 99
Ranger
Have you driven the 6060 transmission in cold weather? There is an issue on the 1-2 (and sometimes the 2-3) for a lot of 2008 and 2009 owners. After 5 - 10 miles of warm-up the notchiness goes away. Some of us are looking at a fluid change to see if better cold start-up propoerties can be found.
Old Jul 24, 2009 | 02:58 PM
Ranger's Avatar
Ranger
I've driven a 2009 Z06 in late November. It's cold-weather start-up tranny behavior was very similar to what I've experienced in all the C5s and C6s I've driven. Once the driveline is warmed up (surrogate=oil temp above 100*F), shifter action smoothes out.
I've driven five different Corvettes with the 6060. Sweetest tranny ever in a Covette. But like all Corvette trannies, it requires that the driver be patient until the driveline is warmed by driving the car.
Just a thought.
Ranger
To Manual trans fluid recommendation
Old Jul 24, 2009 | 03:28 PM
Robls6's Avatar
Robls6
I just had a new RPM stage 5 trans built and installed by RPM in my A&A supercharged 07. They filled the trans with O'Reilley parts store Dextron and said that's what they use. It's all the same.
Old Jul 24, 2009 | 04:25 PM
JayplaySS2's Avatar
JayplaySS2
Do what you want.
Tremec T56 in my Cobra with 20K mile stock fluid = suck at grinding and hanging up in neutral and speedshifting.
Tremec T56 in my Cobra with Syncromax fluid = speedshifting with no worries about 2nd or 3rd and zero hanging in neutral.
Do what you want but I am sure everything, including GM fluid, can be improved upon. Not to mention that we all know 3-5 rwhp can be found by going to a higher quality sysnthetic lube......I hope we know that anyway.
Old Jul 24, 2009 | 08:28 PM
tomiboy's Avatar
tomiboy
Just a thought.
Ranger
I just skip 2nd gear for the 1st 10-15 minutes
