Wrist pin retainer removal
Old Jul 26, 2009 | 01:12 AM
dfinke23's Avatar
dfinke23
Default Wrist pin retainer removal
How do you remove the wrist pin retainer clips from the piston?
Old Jul 26, 2009 | 08:50 AM
black06vette's Avatar
black06vette
Make a notch in the piston with a dremel or similar tool so that you can get a pick in the groove and pop it out. Interestingly enough the service manual shows this notch, LOL. I guess they forgot about it in the casting.
Old Jul 26, 2009 | 08:51 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Detonate it
or
Rotate the retainer until the gaps are positioned in the cutout area. Then use a pic or pocket screwdriver to push the ring end towards the piston pin and scroll around the retainer, an L shaped pick works best.
For illustration only
Old Jul 26, 2009 | 02:13 PM
dfinke23's Avatar
dfinke23
The stock LS7 pistons do not have that cutout.
Old Jul 26, 2009 | 07:46 PM
glenB's Avatar
glenB
AH, it's a 7L, that sucks, but it's probably because GM says to service as a unit.
So, I would do as suggested above and hit with a wizzer .....
or
buy new rods
To Wrist pin retainer removal
