electrical wiring 101
Old Jul 27, 2009 | 06:09 PM
Finster07's Avatar
Finster07
Default electrical wiring 101
Anyone have a link to basic car electrical wiring where it discusses how you determine the gauge wire and size of the fuse based on the amperage draw?
thanks
Old Jul 27, 2009 | 08:22 PM
thoyer's Avatar
thoyer
thanks
You can do a google search on wire ampacity and lots of sites with charts come up. The fuse is sized to protect the wire so if you have a wire rated for 20 amps, you don't want a 30 amp fuse protecting it. The wire will become the fuse in this case.
Fuses are also sized based on inrush current which is the initial current draw when a circuit is powered. For example, your A/C blower may normally pull 9 amps during operation, but have an inrush of 20 amps when it is first turned on, thus necessitating a 25 amp fuse and the associated wire gauge. This is a very generic example, the duration of the inrush also factors into fuse selection.
Tom
