swapping skins out
Old Jul 27, 2009 | 08:21 PM
blackvetterzo6's Avatar
blackvetterzo6
Default swapping skins out
Not for the faint of heart. Did the passanger seat tonight 3 hours. Forget the hog rings, took my time and it turned out pretty sweet. Only used a couple of staples and 3 cable ties to connect the bottom. Looks prett much OEM. Will try to post pictures.
Old Jul 27, 2009 | 08:23 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
Pics,
were did you get the skins??
Old Jul 27, 2009 | 08:35 PM
blackvetterzo6
From the for sale section. Will have some for sale if your interested.
Old Jul 27, 2009 | 08:41 PM
pmj341's Avatar
pmj341
what color/combo??
Old Jul 27, 2009 | 08:58 PM
blackvetterzo6
Originally Posted by pmj341
what color/combo??
It was easier swapping the skins then posting pictures. 2LZ with airbags, black with red stiching. Excellent cond. Still trying to post.ZO6
Old Jul 27, 2009 | 09:00 PM
silvervette05's Avatar
silvervette05
can't wait to see some pics...i'm sure it looks great..
blackvetterzo6
Hope this works
Old Jul 27, 2009 | 09:01 PM
blackvetterzo6
[IMG]http://i73.photobucket.com/albums/i232/blackvetterzo6/seatskinswap012.jpg[/IMG]
Old Jul 27, 2009 | 09:08 PM
VET4LES's Avatar
VET4LES
They look great.
Old Jul 27, 2009 | 09:12 PM
Mike02z's Avatar
Mike02z
Looks good!
Old Jul 27, 2009 | 09:13 PM
blackvetterzo6
I was impressed with the turnout. I was like WTF am i doing. It took a while but i reworked it at least 3 times. That hammer you see was to drive the new christmas tree plugs. And both those staple guns are a POS. 30 bucks and going right back to lowes when i'm done.
I got the recliner hangle off pretty easy with needle nose pliers. Everybody bitches about that part of install. And GM has pretty cheezy foam for a 70K car.
Drivers side tomorrow. Shouldn't be to bad.
Old Jul 27, 2009 | 09:41 PM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
It takes a while to figure out how to take them apart, but once you do, the next time will take half as long.
I also used tie wraps instead of the hog rings and it seems to work just fine. I used big, thick black ones which seem more than strong enough.
I reworked my driver's seat and agree with the foam being junk. Did you notice that there is no support between the center wires and the bottom seat frame? This is below the bolsters which makes them totally worthless.
When you do the driver's seat, I recommend you glue a thin layer of foam over the steel frame under the bolsters to help prevent the factory foam from tearing as it rubs against the frame. The steel frame edges are fairly sharp and cut into the factory foam over time especially on the outside where you side down to get in and out the of the seat.
I added 3 layers of ballistic nylon fabric between the springs and the foam to firm up the bottom cushion. Ballistic nylon is the stuff they make duffel bags from. This eliminated the hip pain I was getting after only 20 minutes of driving.
Old Jul 27, 2009 | 09:48 PM
blackvetterzo6
Thats a good idea. Might try that. And i was really surprised at the crappy foam, again this is a fantastic car and i love it, but come on.They could of done a much better job. Anyway love the 2-tone color.
Thanks guys
Old Jul 27, 2009 | 10:08 PM
pmj341's Avatar
pmj341
I like the 2 tone !!!
I'm looking for blk/red!!
I have Coverking covers now, I like the design but the fit could be better!!
Old Jul 27, 2009 | 11:33 PM
Mez's Avatar
Mez
Thanks guys
Most definitely glue something on the frame to prevent it from cutting into the bolster seat foam. I thought about gluing some polyester or cotton batting on the frame. Let me know what you come up with.
I thought about slicing an inch off the bottom foam and replacing it with denser foam. But tried the nylon cloth first. This works but I would like to experiment with some denser foam. The top of the foam has the seat heater and Velcro fastener for the leather skin, so I did not want to mess with the top layer.
In the picture below, I put a strip of duct tape over the frame to hopefully keep it from cutting into the foam. The edge is really sharp.
In this picture, the red arrows highlight the fact there is no support under the side bolsters. I don't have a quick and cheap fix for this yet.
Old Jul 28, 2009 | 06:22 AM
blackvetterzo6
Thanks for all the ideas. Drivers seat probably tonight.
Old Jul 28, 2009 | 07:13 AM
Mez's Avatar
Mez
By the way, the seats are manufactured by Lear who went chapter 11 last month.
To swapping skins out
Old Jul 28, 2009 | 11:49 AM
BEZ06's Avatar
BEZ06
Lookin' GOOD!!!
That 2-tone color combo is CL!!!
Bob
Old Jul 28, 2009 | 03:55 PM
blackvetterzo6
Drivers side done, all in all wasn't bad. Another 3 hours, hardest time was getting the trim piece back on the side where the controls are. Used no hog rings at all. I'm sure a upholsterer could of done a little better job, but i saved myself 250. Worst case scenario, i can have the seats out in about 10 minutes each.
Old Jul 28, 2009 | 04:39 PM
blackvetterzo6
You can tell the drivers seat is a little worn. Next time i do the new foam cushion also. I couldn't strech it anymore then i did.[IMG]http://i73.photobucket.com/albums/i232/blackvetterzo6/seatskinswap020.jpg[/IMG]
