Is the LS3 padding/cover necessary?
Old Aug 3, 2009 | 09:18 AM
OutKlast's Avatar
OutKlast
Default Is the LS3 padding/cover necessary?
I swapped LS3 heads and LS3 intake into my C5 corvette. Found out the LS3 intake is just to tall with the padding/cover on it. It fits just fine without it though.
I have maybe the thickness of a pencil in clearance with the padding/cover gone. It's so tight it wouldn't even fit with just the plastic cover and no padding.
What does that padding do? Is it just to quiet the engine down?
Old Aug 3, 2009 | 10:40 AM
nwc6's Avatar
nwc6
Correct it is an acoustical shield. Several on here have removed theirs...
Old Aug 3, 2009 | 11:21 AM
OutKlast's Avatar
OutKlast
Ahhh good to know. I was going when it didn't fit. I thought I remembered someone saying it damped vibrations that threw off airflow at high RPM's or something.
Old Aug 3, 2009 | 01:15 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I don’t mean to rain on your parade, but have you actually tried to fire it up yet? The reason I ask is that I was talking to somebody about this very same thing last week and was told that while they will physically bolt up to the engine the difference in the bore size is going to cause the valves to hit the side of the cylinders.
Please let me know if it does work as I have a friend who was considering this same mod but decided not to after being told it wouldn’t work.
Christopher
Old Aug 3, 2009 | 06:46 PM
OutKlast's Avatar
OutKlast
Christopher
I have a "FrankenMotor", it's bolting up to a 408ci LQ9 (Iron truck block). You can't run the bigger bore LS3 on a smaller bore engine like the 349ci, that is correct. But it does fit and run on a bored out motor.
Fired it up today, need to add spacers to the valve covers but other then that it started up and ran fine.
Old Aug 3, 2009 | 07:23 PM
thesubfloor
Okay, that makes sense then. Thanks for the update.
Old Aug 4, 2009 | 12:47 AM
rcmigpilot's Avatar
rcmigpilot
It knocks down the valve train noise and nothing else. I had to take mine off when I tapped the vacuum source for my mild to wild retrofit kit. It was such a pain to get it back in I left it off and noticed a significant increase in unwanted engine noise. My motor sounded way too much like a sewing machine so I put it back on.
Old Aug 4, 2009 | 07:04 PM
SSJCreeper's Avatar
SSJCreeper
I pulled my coil covers a couple weeks ago in preparation for headers and a coil relocation kit. The intake cover stood out once the coil covers were removed so I yanked the intake cover as well. It could just be me, but I can't say I've noticed a significant change in valvetrain noise as a result of pulling the intake cover. Maybe I'm going deaf. Huh?
Old Aug 5, 2009 | 10:13 PM
steppindown's Avatar
steppindown
Default And the coil packs??
And the coil packs are where?
To Is the LS3 padding/cover necessary?
