09 Bluetooth problems
Old Aug 7, 2009 | 08:47 PM
3 Speed's Avatar
3 Speed
Default 09 Bluetooth problems
I have Iphone 3G that allows me to make calls outbound, but will not allow me to answer inbound calls from the steering wheel controls. I used to be able to answer on the phone, and then it would link to the car, but after the most recent software upgrade on the Iphone it wont even do that now.
I called GM months ago and they said it's Apple's fault. Apple says it's GM's fault. Has anyone had or resolved this problem?
Thanks!
Old Aug 7, 2009 | 08:55 PM
calemasters's Avatar
calemasters
Try someone else's known good phone with blue tooth. That should tell you if it is the phone or the car.
Old Aug 7, 2009 | 09:05 PM
danl72's Avatar
danl72
Actually, I think it is the phone. I have an issue linking my 3Gs with bluetooth in other cars as well.
Old Aug 8, 2009 | 04:26 PM
m453w's Avatar
m453w
Cruising
I found on my 3G (w/ 3.01 s/w) that it is an issue with how long you hold the answer button down on the wheel. Too short - it just mutes the sound system audio. Hold it a little longer - and it works. But it is a little too touchy, I would agree. Good luck.
Old Oct 23, 2009 | 05:35 PM
Deftly's Avatar
Deftly
Is this still an issue? I am thinking of getting an IPhone, but I don't need the hastle w/bluetooth.
Old Oct 24, 2009 | 09:56 AM
3 Speed's Avatar
3 Speed
Default Issue solved
Apple recently sent a software update out for the Iphone and guess what? It fixed the problem. You DO have to hold the answer button down at least a second, (as someone else recomended), but its all a go for now.
Old Oct 24, 2009 | 08:49 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
I answer on the phone (just pressing the answer button), but it goes through the blue tooth.
I have tried pushing the steering wheel controls, but NOT holding the button. I will try that.
Ron
Old Oct 25, 2009 | 11:29 PM
MikeLeal's Avatar
MikeLeal
mine works fine, you just have to hold the button down when answering
Old Oct 26, 2009 | 03:22 AM
MarylandSpeed's Avatar
0MarylandSpeed
Former Vendor
Mine works fine also.
To 09 Bluetooth problems
