Skipping/hopping/bad shocks?
Except sometimes in a turn, if theres a bump or rough spot in the road during the turn, it will sometimes skip/hop.
Anyway, apparently the Bilstein sport shocks are the way to go, and thats what I've ordered. don't know if they will cure the problem you describe, but they will definitely improve handling characteristics. Thats what others have told me. Z51 sways next.
For what its worth I put Bilstein Sports on my car and the difference in how it rides was very minimal. It helped a lot with wheel hop, but that's wheel hop I was getting from lighting up the tires in a straight line....
Took it to a dealer, they swapped the lube again. That didnt' help so I took it back. This time after 15 minutes with the shop forman explaining to him what a locked rear diff would do (he really didn't seem to understand), he agreed to call his tech rep (whatever that is). He called back a half-hour later and told me they had seen this before and he's going to replace the clutch plates in the rear diff.
In a nutshell, the rearend has clutch plates in them that can slip. The fluid will work its way in between them allowing them to slip a little. The original fluid didn't work well so the plates were constantly binding/releasing/binding/releasing - that's what caused the chatter. The new fluid does what - let them slip more? I'm not sure but it doesn't sound good. Anyway, what seems to have happened is that the plates are permanently locked now so there is no slip at all. That's why I get the binding/hopping when turning slow and sharp. Just ordered a new set of Firestone Firehawks to replace the Goodyears. It sickens me that I only got 17K miles out of the first. I never, ever spin the tires and I'm gentle with it, so should have gotten well over 20K out of the goodyears. That combined with the jumping all over the road that seems to be bad on runflats, but much worse on the goodyears convinced me to go with a different MFG. the Firehawks are cheaper, have longer treadwear, corner as well (reportedly) and are made specifically for the C6.
I'll re-post after the dealer replaces the plates.
