Paddle shifters - C6
Old Aug 14, 2009 | 09:35 AM
Irish Whiskey's Avatar
Irish Whiskey
Default Paddle shifters - C6
The new european paddle shifters smoothly change gears in 100 milliseconds. The computer no longer overrides manual shifts as well.
What about the C6 paddle shifter system? Has the speed of shifting increased and what is that speed?
What about the seamless shifting of the gears? smooth?
Does the computer override your manual paddle shift when you do something it does not like??
Old Aug 14, 2009 | 06:31 PM
PCMusicGuy's Avatar
PCMusicGuy
You can't really compare a dual clutch paddle shifting transmission with what we have in the vettes. Think of ours as a regular automatic transmission (fluid torque converter based) with the ability to change and hold gears manually. Our shift times are slow compared to a dual clutch and will not be as smooth. The computer in your will protect your drivetrain to a point, i.e. it won't let you shift into 6 gear below 40 mph, etc.
Old Aug 15, 2009 | 08:07 AM
Irish Whiskey
GM's "parts off the shelf" policy strikes again!! Cost I guess is the issue.
Old Aug 15, 2009 | 08:24 AM
Jeffyvette's Avatar
Jeffyvette
Default Better then stock
The shifts can be programed to be more crisp and quick, but nothing like a true dual clutch set up.
Jeffy'
To Paddle shifters - C6
