TPMS question do I need to get it reset everytime?
I assume the answer is "yes" or people would have issues swapping out tires at the track...where it may be difficult to have a "tire sensor reset" (A-tech/Shrader) tool on hand.
thanks in advance for your insight,
However, I think you are saying that you have 2 complete sets of wheels/tires/sensors, i.e. a different set of sensors in each set of wheels/tires.
If that's the case, then NO, you cannot just swap between sets without programming the sensors each time you do it.
The TPMS computer can hold 4 sensor ID#s in its memory, so when you program a set of sensors into the TPMS, any old ID#s are dropped out.
You can get a tool from a couple of forum vendors. Katech has the Bartec Trackside for $140, and Tire Rack has an ATEQ VT10 for $105.
Every time I put on my track wheels/tires/sensors I have to do a relearn procedure, and when I swap back to my street tires I do the relearn procedure again - it only takes about a minute.
Bob
I didn't realize you needed to use the "reset tool" every time.
http://www.youtube.com/watch?v=GnyNBgWHDeg
Thank you for your advice!
BTW in my video in the link above you can see what our C6 sensors look like - they're a gray peanut shaped sensor - and they work in all our C6 model years from 2005 to 2009.
Initially I thought the 2010 would certainly be the same, however, and I'm not sure at all about this yet, but the 2010 may have a different TPMS computer in the car that requires a different sensor.
I've been having a hard time getting info on the 2010 model, but the list of RPO codes I've seen indicate that the TPMS has an RPO of UJM (all 2006 to 2009 C6s made for the North American market had a UH3 TPMS). Maybe they've just changed the RPO code for the same piece of equipment, but UJM has been in previous years on several other models of GM vehicles (the Malibu, a Buick, and several others) and it uses a different part# sensor than our C6 uses.
IF the 2010 uses a different sensor, it MAY be possible to program the sensors using the "change of pressure method", i.e. you can put the car into the learn mode and simply increase or decrease the tire pressure about 10 psi until you get a honk of the horn. I think they will trigger with a tool as well.
IF the 2010 uses different sensor, I think I'd still prefer to use a tool at the track - I think that would be a lot easier unless you have a compressor handy in your paddock area, and probably a lot quicker too because you'd have to go around and reset all your tire pressures after you're done.
Anyway....not sure at all about the 2010s yet!
Bob
