Help "service charging system"
Old Aug 27, 2009 | 03:15 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, sorry, I never re-opened the original post but that last entry in it was something like that seemed to resolve it and would keep watching. I still am, but so far zero problems with the charge system fault after going back to Ac Delco plugs from the NGK's that I had tried and we discovered through you that it was a possible cause...it was indeed.
Old Sep 5, 2009 | 07:30 PM
Invisiguard's Avatar
Invisiguard
getting this warning too, my volts wont go above 11v no matter how low/high the RPMs, changed the battery AND the alternator, nothing!!
GRRRR!!
Im sure its not the plugs thats dropping my voltage, any other ideas?
Old Sep 7, 2009 | 02:50 PM
C6 Doberman's Avatar
C6 Doberman
I'm having the same issue with my 07'. Tuner told me it was the aftermarket plugs. Doesn't really bother me because my voltage is fine.
Old Sep 8, 2009 | 12:02 PM
Wingrider's Avatar
Wingrider
I had enough of this and with an HP tuner, went into the trouble codes and simply turned the code off. End of problem. (The dealer said my battery and alternator were fine, no charging issues. Apparently a computer glitch.)
Old Sep 9, 2009 | 05:13 PM
ArmySpeedFreek's Avatar
ArmySpeedFreek
sorry for taking so long to get back to this but it was the alternator just to settle this issue
Old Sep 9, 2009 | 10:09 PM
dgrant3830's Avatar
dgrant3830
Glad your issue was the alternator even though it had to be at a bad moment out on the road. We're just adding that some of us, for others to read, have had other issues that also caused the charge system fault, even if they sounded way out in left field. More knowledge for all of us to consider is better than none.
Old Sep 11, 2009 | 06:42 PM
ArmySpeedFreek
its sad that the c6 doesn't seem to have a s good an alternator as the c5 did
